Home Assistant novice. Installed first device - Cloudfree Smart Bulb RGBCW (ESP8266) converted from native Tasmota to ESPHome without issue. All HA entity controls appear to work as expected.
Problem - Under the Tasmota firmware the bulb could be On/Off controlled by the main power wall switch. Now the bulb can only be turned Off with wall switch, not On.
Continuing research appears to suggest the CF Bulb firmware needs to include installed firmware code similar to below for a Sonoff S31 plug which also has a physical main AC power On/Off switch.
Think the “binary.sensor” section of code above is on the right track. Just would be great to get some experienced confirmation and correct pin needed. Or feedback on potentially damaging the bulb if guessing wrong on pin assignments.
Also, is there a better forum to be asking this type of question?
