Has anybody else been having CloudMQTT issues today? My OwnTracks device tracker has stopped working and the CloudMQTT is giving a security warning saying their SSL/TLS certificate expired (the expiry date seems to be today).
Yea still seeing this. Owntracks works again on my phone but HASS still won’t connect to it. The website is still showing an expired certificate.
As a workaround I changed the port in my config file from 2xxxx to 1xxxx (keep the other 4 numbers the same) and got it working again. I think the 1xxxx ports are not using SSL, so its not ideal but should get you running until they get the certificate updated.
I’ve got it working with SSL again. I had restarted HASS several times and it made no difference (even though OpenSSL was saying the certificate was valid), what worked was adding certificate: auto
to my mqtt configuration and restarting HASS. The configuration now looks like this:
mqtt:
broker: *.cloudmqtt.com
port: 2****
certificate: auto
username: *****************
password: *****************
Somehow, with the new SSL certificate configuration, this is now needed when it was not needed before. I tried changing the configuration back, in case this was just coincidence and it had been fixed anyway, but it broke again with the same SSL error.
Thanks for the tip! The certificates were apparently fixed in 0.79.2
, but I was still seeing SSL cert errors in my cloudmqtt logs. Adding certificate: auto
to my mqtt config and restarting home assistant worked for me (running 0.80.3
Hi there,
mqqt is still the most troubling integration in Home Assistant for me.
I also had expired certificates in MQTT, while home assistant itself was fine!
Maybe someone can confirm this: Restarting Home Assistant does not restart MQTT. In this case MQTT would stick with the old certificate. Restarting MQTT manually fixed the outdated certificates.
Should it restart on a new certificate automatically? This is what Let’s encrypt needs.
btw: I get my certicates not from the internal LE addon.
