CMUS setup wont connect
Trying to connect to a remote CMUS instance on a raspberry pi zero w but HA will not connect.
Environment:
HA running in docker container
CMUS running on a raspberry pi zero w with --listen 0.0.0.0 and a password set
Relevant configuration entry:
    media_player:
      - platform: cmus
        host: 10.0.6.32
        port: 3000
        password: SomePassword
Error:
Error while setting up platform cmus
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/media_player/cmus.py", line 51, in setup_platform
    cmus_remote = CmusDevice(host, password, port, name)
  File "/usr/src/app/homeassistant/components/media_player/cmus.py", line 68, in __init__
    server=server, password=password, port=port)
  File "/usr/local/lib/python3.6/site-packages/pycmus/remote.py", line 79, in __init__
    "Unable to connect to server %s" % self.server)
pycmus.exceptions.ConfigurationError: A configuration error occured
Details: Unable to connect to server 10.0.6.32
Steps I’ve done trying to debug the problem:
  1. Restart HA (docker instance)
  2. Install pycmus on my desktop, and connected using same code as cmus.py like 67-68
  3. docker exec -it hass python and do the same thing
  4. import the cmus.py into repl and manually created a CmusDevice
All steps connect just fine and allow me to do a get_status_dict() or a device.status after an update without an error… yet HA refuses to connect with the exact same error msg.
example of what I typed into the repl:
    from homeassistant.components.media_player import cmus
    q = cmus.CmusDevice('10.0.6.32','SomePassword', 3000, 'test')
    q.update()
    q.status
    {'tag': {}, 'set': {'aaa_mode': 'all', 'continue': 'true', 'play_library': 'true', 'play_sorted': 'true', 'replaygain': 'disabled', 'replaygain_limit': 'true', 'replaygain_preamp': '0.000000', 'repeat': 'false', 'repeat_current': 'false', 'shuffle': 'false', 'softvol': 'false', 'vol_left': '0', 'vol_right': '0'}, 'status': 'stopped'}
Not sure where to move forward and would love some guidance.
Thanks in advance.
Upgrading to 0.73 without any config changes alleviated the issue… /shrug thanks for looking!
