CO₂ Progressive Alerts (multi-device, area-aware, cooldown, “only-if-home” toggle)
CO₂ - Progressive Alerts (multi-device, area-aware, cooldown, “only-if-home” toggle)
GitHub Link Click Here for Issues
TL;DR
A robust CO₂ alert blueprint that:
  • Triggers on Warn / Alert / Critical thresholds (each with its own for: duration)
  • Notifies multiple Companion App devices and/or any notify.* entities
  • Optional “only if devices are at home” gate (default on)
  • Adds the sensor’s Area to the notification title (if defined)
  • Has a cooldown to prevent spam
  • Emits rich Logbook diagnostics for troubleshooting
  • Uses notify.send_message where available and falls back to legacy notify.mobile_app_<slug> for phones
What it does
  • Monitors a CO₂ sensor (device class carbon_dioxide).
  • Sends progressive notifications:
    • WARN — default 1000 ppm, for: 5 min
    • ALERT — default 1400 ppm, for: 3 min
    • CRITICAL — default 2000 ppm, for: 1 min
  • Title includes the Area of the CO₂ sensor: e.g., Air quality — Kitchen.
  • Cooldown (default 15 min) between any two notifications.
  • Mobile notifications go to selected Companion App devices:
    • If “Notify only if devices are at home” is enabled (default), the blueprint resolves each device’s
      device_tracker.* and sends only when it’s home.
    • If disabled, it sends regardless of presence.
  • Also supports additional notify.* entities (notify groups, Telegram, etc.).
Inputs
Input Type Default Notes
CO₂ sensor sensor (device_class: carbon_dioxide) Source for ppm
Mobile app devices list of device (integration: mobile_app) [] One or more phones/mac with Companion App
Notify entities (optional) list of entity (domain: notify) [] Any notify.* targets (groups, Telegram, etc.)
Notify only if devices are at home boolean true Presence gate using each device’s device_tracker
Warn threshold / for number / minutes 1000 / 5 First level
Alert threshold / for number / minutes 1400 / 3 Second level
Critical threshold / for number / minutes 2000 / 1 Third level
Cooldown (minutes) number 15 Minimum gap between any two sends
Debug logging to Logbook boolean false Verbose Logbook traces everywhere
How notifications are sent
  • If your target exposes notify.* entities, the blueprint uses notify.send_message with target.entity_id.
  • For Companion App phones, if no notify.* entity exists on the device, it falls back to legacy *
    notify.mobile_app_<slug>* (slug derived from the device’s device_tracker object_id).
    This avoids templating device_id (which device actions don’t support inside loops) and works reliably with multiple
    devices.
Logbook diagnostics
When Debug is on, each run logs:
  • Trigger level, ppm, thresholds, Area
  • Cooldown timing (last_triggered, seconds_since, decision)
  • Per device: found device_tracker, state, any notify.* on the device, computed legacy service name
  • Which path was used to send (entity vs legacy) or why it was skipped
This makes it easy to see exactly why a device did or didn’t get a push.
Install
  1. Open Settings → Automations & Scenes → Blueprints.
  2. Import Blueprint and paste the Gist URL above.
  3. Create a new automation from this blueprint:
    • Pick your CO₂ sensor.
    • Select your phones (Companion App devices).
    • (Optional) select extra notify.* entities.
    • Adjust thresholds/durations/cooldown if needed.
Tips & troubleshooting
  • No notification on a phone?
    Check the Logbook entry. Common causes:
    • Presence gate: device not home (toggle “Notify only if devices are at home” off to test).
    • No device_tracker.* on that device (Companion App presence/permissions).
    • The device doesn’t expose a notify.* entity; fallback uses notify.mobile_app_<tracker_slug>. The log shows the
      exact name used.
  • Want different thresholds per room?
    Create multiple automations from this blueprint, one per sensor/room.
  • Too chatty?
    Increase for: times and/or cooldown_minutes.
  • Noisy logs?
    Turn off Debug logging to Logbook in the inputs.
Changelog
  • v1.0 – Progressive levels, multi-device, area-aware title, presence gate (toggle), cooldown, Logbook diagnostics,
    hybrid notify (entity + legacy mobile fallback).This text will be hidden
