Since a few days ago CO2 Signal stopped working. The integration says either unavailable or unknown as per the screenshot. To my knowledge I didn’t change anything that could have tampered with it. Initially I told it to use my Home location, but I’ve tried deleting the integration and re-adding it with lat/longitude in hopes of it picking up again, but alas, no success. Restarting HA or rebooting my RPi3 doesn’t help.
The diagnostics are below. The HA log doesn’t show anything that might seem related, but I could always share it if requested.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.3.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.9.9",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "5.10.92-v8",
"supervisor": "2022.03.3",
"host_os": "Home Assistant OS 7.4",
"docker_version": "20.10.9",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"hacs": {
"version": "1.23.0",
"requirements": [
"aiogithubapi>=21.11.0"
"integration_manifest": {
"domain": "co2signal",
"name": "CO2 Signal",
"documentation": "https://www.home-assistant.io/integrations/co2signal",
"requirements": [
"co2signal==0.4.2"
"codeowners": [],
"iot_class": "cloud_polling",
"config_flow": true,
"loggers": [
"CO2Signal"
"is_built_in": true
"data": {
"config_entry": {
"entry_id": "f70572426841c396693b96e7e91e7e10",
"version": 1,
"title": "CO2 Signal",
"data": {
"api_key": "**REDACTED**",
"latitude": "**REDACTED**",
"longitude": "**REDACTED**"
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "user",
"unique_id": null,
"disabled_by": null
"data": {
"_disclaimer": "This data is the exclusive property of electricityMap and/or related parties. If you're in doubt about your rights to use this data, please contact [email protected]",
"status": "ok",
"countryCode": "NL",
"data": {
"fossilFuelPercentage": null
"units": {
"carbonIntensity": "gCO2eq/kWh"
Does anyone have a clue why it isn’t working? Many thanks in advance!
