Cod.m ZigBee Coordinator - LAN - Z2M
does anyone have the above running under HA? i want to replace SonoffDongle 3 with z2m.
Is it possible to run 2 coordinators at the same time? Will the mqtt entities be retained after a coordinator switch?
The coordinator runs as zstack not es ezsp, how to change it
cod.mSupport is not very helpful and only sends me links to the videos
The error before I have undone everything
zh:ezsp:ezsp: Connection attempt 2 error: Error: connect ECONNREFUSED 172.30.32.1:9999
no idea where the 127.30.32.1:9999 came from
LOG:
[CODE][13:17:06] INFO: Preparing to start…
[13:17:07] INFO: Socat not enabled
[13:17:09] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-07-09 13:17:17] info: z2m: Logging to console, file (filename: log.log)
[2024-07-09 13:17:17] info: z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-09 13:17:17] info: z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-09 13:17:17] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-07-09 13:17:18] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: connect ECONNREFUSED 172.30.32.1:9999
at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)
[2024-07-09 13:17:23] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: connect ECONNREFUSED 172.30.32.1:9999
[2024-07-09 13:17:33] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: connect ECONNREFUSED 172.30.32.1:9999
at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)[/CODE]
Config/Yaml
[CODE]data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt:
base_topic: zigbee2mqtt
user: mqtt
password: mqttxxxx
server: mqtt://192.168.1.155:1883
serial:
port: tcp://192.168.1.150:6638
baudrate: 115200
advanced:
transmit_power: 20[/CODE]
serial:
  adapter: ezsp
  baudrate: 115200
and
adapter: zstack does nothing
question was not clear, but if it is this one:
serial:
  adapter: zstack
  baudrate: 115200
thanx, tried it but same errors in the log
[09:32:16] INFO: Preparing to start...
[09:32:16] INFO: Socat not enabled
[09:32:19] INFO: Starting Zigbee2MQTT...
[2024-07-10 09:32:25] info: 	z2m: Logging to console, file (filename: log.log)
[2024-07-10 09:32:25] info: 	z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-10 09:32:25] info: 	z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-10 09:32:26] info: 	zh:zstack:znp: Opening TCP socket with 192.168.1.150:6638
[2024-07-10 09:32:26] info: 	zh:zstack:znp: Socket connected
[2024-07-10 09:32:26] info: 	zh:zstack:znp: Socket ready
[2024-07-10 09:32:26] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-07-10 09:32:27] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-07-10 09:32:45] error: 	z2m: Error while starting zigbee-herdsman
[2024-07-10 09:32:45] error: 	z2m: Failed to start zigbee
[2024-07-10 09:32:45] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-10 09:32:45] error: 	z2m: Exiting...
[2024-07-10 09:32:45] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:101:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
    at Zigbee.start (/app/lib/zigbee.ts:63:27)
    at Controller.start (/app/lib/controller.ts:139:27)
    at start (/app/index.js:154:5)
[09:32:46] INFO: Preparing to start...
[09:32:47] INFO: Socat not enabled
[09:32:49] INFO: Starting Zigbee2MQTT...
[2024-07-10 09:32:56] info: 	z2m: Logging to console, file (filename: log.log)
[2024-07-10 09:32:56] info: 	z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-10 09:32:56] info: 	z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-10 09:32:56] info: 	zh:zstack:znp: Opening TCP socket with 192.168.1.150:6638
[2024-07-10 09:32:56] info: 	zh:zstack:znp: Socket connected
[2024-07-10 09:32:56] info: 	zh:zstack:znp: Socket ready
[2024-07-10 09:32:56] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-07-10 09:32:57] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352```
See this link : Zigbee2MQTT fails to start | Zigbee2MQTT
5 common reasons of this error:
  1. The port of your serial adapter changed. Check this to find out the port of your adapter.
  2. If you are using a CC2530 or CC2531; it is a common issue for this adapter to crash (due to its outdated hardware). Reflashing the firmware should fix the problem. If it happens often consider flashing the source routing firmware
    or upgrade to a more powerful adapter.
  • Your adapter requires additional configuration parameters. Check supported Adapters section to find out if your adapter requires extra parameters (eg. ConBee II / RaspBee II).
  • Home Assistant’s “Zigbee Home Automation” (ZHA) integration is enabled. Try to disable the ZHA integration and restart the Zigbee2MQTT add-on.
  • Your hardware adapter is flashed with the router firmware and not with the coordinator firmware.
  • Your network Zigbee adapter is not accessible over the LAN network
The cod.m zigbee koordinator is connected over LAN
Any of these true ?
ZHA is enabled and serves > 30 devices
But i’ll give it a try
and yes the network zb adapter is accessible
IF ZHA is enabled and tries to use the same Cod.m, Zigbee2MQTT will not start. You could uses your Sonoff dongle with ZHA, and your cod.m with Zigbee2MQTT, or vice versa.
tried it , no changes, but i see in the log
[2024-07-10 09:48:54] info: zh:zstack:znp: Opening TCP socket with 192.168.1.150:6638
[2024-07-10 09:48:54] info: zh:zstack:znp: Socket connected
[2024-07-10 09:48:54] info: zh:zstack:znp: Socket ready
[2024-07-10 09:48:54] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-07-10 09:48:55] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
no for ZHA i’m using the Sonoff Coordinator
no idea why it works now,
ZHA disabled, enabled, HA booted, cod.m reconnected and cod.m zigbee restarted …
thx for your help
now i restored the database.db and all devices must be re-pair-ed, as expected :frowning:
