I’m curious on what I’m doing wrong this this basic code. I’m simply trying to use a switch to toggle the lights on an LED strip:
light:
- platform: fastled_clockless
chipset: WS2811
pin: GPIO1
num_leds: 10
rgb_order: RGB
default_transition_length: 0s
color_correct: [100%, 100%, 100%]
switch:
- platform: gpio
pin: GPIO2
on_turn_on:
- logger.log: "Light Turned On!"
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
on_turn_off:
- logger.log: "Switch Turned Off!"
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
The code compiles fine, but I get the following errors when it tries to boot:
[07:55:30]ets Jun 8 2016 00:22:57
[07:55:30]
[07:55:30]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[07:55:30]configsip: 0, SPIWP:0xee
[07:55:30]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[07:55:30]mode:DIO, clock div:2
[07:55:30]load:0x3fff0018,len:4
[07:55:30]load:0x3fff001c,len:1044
[07:55:30]load:0x40078000,len:8896
[07:55:30]load:0x40080400,len:5828
[07:55:30]entry 0x400806ac
[07:55:31][I][logger:242]: Log initialized
[07:55:31][C][ota:461]: There have been 5 suspected unsuccessful boot attempts.
[07:55:31][D][esp32.preferences:114]: Saving preferences to flash...
[07:55:31][I][app:029]: Running through setup()...
[07:55:31][C][fastled:012]: Setting up FastLED light...
[07:55:31][C][switch.gpio:011]: Setting up GPIO Switch 'fake button'...
[07:55:31][D][switch:017]: 'fake button' Turning OFF.
[07:55:31][D][switch:037]: 'fake button': Sending state OFF
[07:55:31][D][main:373]: Switch Turned Off!
[07:55:31][D][light:035]: 'led_stop_light' Setting:
[07:55:31][D][light:040]: Color mode: RGB
[07:55:31]Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
[07:55:31]Core 1 register dump:
[07:55:31]PC : 0x400d4417 PS : 0x00060f30 A0 : 0x800d7014 A1 : 0x3ffb1870
[07:55:31]A2 : 0x00000000 A3 : 0x00000001 A4 : 0x0000002c A5 : 0x3ffb95b8
[07:55:31]A6 : 0x3f800000 A7 : 0x3f800000 A8 : 0x800d4412 A9 : 0x3ffb1830
[07:55:31]A10 : 0x3ffb18b4 A11 : 0x3ffb18b0 A12 : 0x0000000a A13 : 0x3ffb189c
[07:55:31]A14 : 0x3f800000 A15 : 0x3f800000 SAR : 0x00000007 EXCCAUSE: 0x0000001d
[07:55:31]EXCVADDR: 0x000000c8 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0x00000000
[07:55:31]
[07:55:31]ELF file SHA256: 0000000000000000
[07:55:31]
[07:55:31]Backtrace: 0x400d4417:0x3ffb1870 0x400d7011:0x3ffb1910 0x400d626e:0x3ffb1930 0x400e554c:0x3ffb1990 0x4017056b:0x3ffb1ac0 0x4017057f:0x3ffb1ae0 0x4017061b:0x3ffb1b00 0x400e4e63:0x3ffb1b20 0x400dd059:0x3ffb1b40 0x400d2ab9:0x3ffb1b70 0x400dcf4b:0x3ffb1bc0 0x400d2805:0x3ffb1be0 0x400d2830:0x3ffb1c10 0x401702c1:0x3ffb1c30 0x40170381:0x3ffb1c50 0x400e3109:0x3ffb1c70 0x400e64b6:0x3ffb1cc0 0x400f310e:0x3ffb1fb0 0x4008aa5a:0x3ffb1fd0
[07:55:31]
[07:55:31]Rebooting...
[07:55:31]ets Jun 8 2016 00:22:57
[07:55:31]
[07:55:31]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[07:55:31]configsip: 0, SPIWP:0xee
[07:55:31]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[07:55:31]mode:DIO, clock div:2
[07:55:31]load:0x3fff0018,len:4
[07:55:31]load:0x3fff001c,len:1044
[07:55:31]load:0x40078000,len:8896
[07:55:31]load:0x40080400,len:5828
[07:55:31]entry 0x400806ac
I’ve tried different GPIO pins for the switch (which there is no physical button at the moment). I’m new to writing my own ESPHome code, so any help would be appreciated.
Thanks!
