Hey HA Dev !
Just a thought, I use picture elements to create my House Graphic / Sensor environment and my
Code is large simply as I have alot of sensors ( maybe 50 ? ) and try out alot of interesting effects, which is all great, however even though I try to keep the code managed and clean with good naming conventions its still very challenging to maintain / change / add to this configuration information as its
just alot of code in there.
Suggestion :
If possible would it be doable to have a search function ? Then at least I could look for the
name tags to change stuff instead of always having to scroll down. -
Could some sort of integration to add external editors into the Code Editor be possible so I could maintain the code with the code editor of my choice ? Sure I can cut and paste the code in and out of the code editor, which I in fact sometimes do but this is obviously fraught with snafu possibilities
Could there be anyway to contextually colour code the code in the editor ? So names or attributes would have different colours ?
Would a “filter” be possible so I could just see the entities names for instance and then click on something to expand the code at that point ?
Anyway thanks for simply listening, HA is fantastic, unbelievable, the challenge is being able to interact with the huge amount of features in a way that makes such a complex system manageable and at the moment at least on this point I’m struggling.
Best regards and thanks
David
