Hello, i made a sketch awhile back for some smart blinds which works perfectly on the older version of ESPhome. however im setting up a homeassistant server for someone else and i want to use esphome again for blidns as i know it works well. the issue is they released a new version which wont allow me to use the same code. ive fixed most issues but this one thats left is out of my league as i dont know much about code. heres the error message and code.
binary_sensor:
- platform: gpio
pin: D3
filters:
invert:
on_press:
then:
- lambda: |
if (id(kitchen_window).state == cover::COVER_OPEN) {
if (id(shade_s1).state){
// shade is opening
id(kitchen_window).make_call().set_command_stop();
} else {
// shade is open and not moving
id(kitchen_window).make_call().set_command_close();
} else {
if (id(shade_s2).state){
// shade is closing
} else {
// shade is closed and not moving
id(kitchen_window).make_call().set_command_open();
