Code Improvement Request
Hey community!
You know that sometimes you start out out with an idea and it rolls on and eventually you get so caught up in the journey that you can no longer see above the weeds? Yeah, that me right now.
The project seemed pretty simple on paper; I have a chamber that I want to control to some fairly tight tolerances in terms of temperature and humidity. I’ve got prototype hardware built using a fan and heater from a small space heater that runs 120v and I plan to control fan speed and heat output by having an ESP32 switch solid state relays. I can’t use PWM due to the 120v causing electrical noise and interference. Sensors are a pair of BME280, one for control and one as a reference in a different part of the box, mostly for testing purposes to make sure I don’t have hotspots or cold spots. Anyways, that’s the background…
I’ve mostly debugged the code except for one issue that is related to float vs binary outputs. What I would like to ask is for folks to take a look and tell me if the code can be improved. It is not going to interface with HA, I need this to run entirely standalone on an ESP32 and I’ll connect via a simple phone app.
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
  - platform: bme280
    address: 0x76
    temperature:
      name: "Box Control Temperature"
      oversampling: 16x
    pressure:
      name: "box Control Pressure"
    humidity:
      name: "Box Control Humidity"
  - platform: bme280
    address: 0x77
    temperature:
      name: "Box Reference Temperature"
      oversampling: 16x
    pressure:
      name: "Box Reference Pressure"
      oversampling: 16x
    humidity:
      name: "Box Reference Humidity"
    update_interval: 60s
output:
  - platform: gpio
    pin: GPIO16
  - platform: gpio
    pin: GPIO5
switch:
  - platform: output
    output: heater_ssr
  - platform: output
    output: fan_ssr
fan:
  - platform: speed
    output: fan_ssr
    speed_count: 100
    on_turn_on:
      - output.turn_on: fan_ssr
    on_turn_off:
      - output.turn_off: fan_ssr
  - platform: speed
    output: heater_ssr
    speed_count: 100
    on_turn_on:
      - output.turn_on: heater_ssr
    on_turn_off:
      - output.turn_off: heater_ssr
interval:
  - interval: 1min
    then:
      - lambda: |-
          float desired_temp = 35.0;
          float temp_tolerance = 0.5;
          if (id(box_control_temperature).has_state() && id(box_control_humidity).has_state()) {
            float temperature = id(box_control_temperature).state;
            float humidity = id(box_control_humidity).state;
            // Calculate box control temperature
            float box_control_temperature = temperature + ((humidity - 50.0) / 5.0);
            // Check if current temperature is below desired temperature minus tolerance
            if (box_control_temperature < desired_temp - temp_tolerance) {
              id(heater_fan).set_speed(50);
              id(heater_ssr).turn_on();
            } else {
              id(heater_fan).turn_off();
              id(heater_ssr).turn_off();
