I have the following working automations for turning lights OFF and sunset and ON and sunrise. I’d like to see the ways I can improve this. The main thing I’m looking to improve right now is the fact that I have to repeat “-5” in four different places. It would be nice to have something like a global variable I can set -5 to, and then reference that variable in all the places that need it, so that as I make adjustments to this I don’t need to make so many repetitive changes.
Also the two automations are similar enough that I wonder if I can reasonably combine the two into one somehow.
Lastly, I added the home assistant start & automation reload triggers because I want to see the lights turn on if those situations happen. On restart is certainly important (in case HASS had been down for a number of hours), the automation reload I’m not sure if I need or not.
That will make the automation trigger all the time and not only when it crosses the threshold (-5 in this case), so if he turns off the lights manually the system will turn on it back right after any small change at the angle (which is all the time).
But if that is the desired effect (it will turn on/off when restart or when reload the automations anyways) then you’re right, it will be even cleaner.
Unless you want to have a card in your dashboard to select this threshold, I wouldn’t use a helper for this.
If your goal is just to reduce the points of maintenance in your c8de you should consider using Blueprints.
I cannot test the code right now, but it would be something like this:
blueprint:
domain: automation
name: Turn lights on or off at sunset or sunrise
description: This automatioj will turn lights on or off whe the Sun crossed an elevation threshold.
source_url: https://community.home-assistant.io/t/code-review-turning-lights-off-on-at-sunset-runrise/473105/8
input:
light_entities:
description: Please select the lights or switches you want to toggle when the Suj crosses the threshold.
default: [ ]
selector:
entity:
multiple: true
domain: [light, switch, group]
sun_threshold:
name: Sun threshold
description: Select the Sun angle where the lights will toggle.
default: -5
selector:
number:
min: -90
max: 90
step: 0.1
mode: slider
unit_of_measurement: °
sun_entity: # It's good to ask for this entity as some user might have changed from sun.sun.
description: 'Typically is ''sun.sun'' (which can be added with the Sun integration).'
default: 'sun.sun'
selector:
entity:
multiple: false
domain: [sun]
mode: single
- platform: numeric_state
entity_id: !input sun_entity
attribute: elevation
below: !input sun_threshold
above: !input sun_threshold
- platform: homeassistant
event: start
- platform: event
event_type: automation_reloaded
condition: []
variables:
sun_threshold: !input sun_threshold
sun_entity: !input sun_entity
- service: >-
homeassistant.turn_{{ iif(state_attr(sun_entity, 'elevation') < sun_threshold, 'on',
'off') }}
entity_id: !input light_entities
By the way, I noticed you are using the old group mode to group your lights. Try to create a group helper (Settings > Device & Services > Helpers). Personally, I like more, as the group behaves just like a normal light entity and it’s almost transparent to the system, making easier to use it.
It would create a new light entity, like light.outside_lights and you will be able to use in light.turn_on service, etc.
The advantage of the legacy groups is that they can include entities from multiple domains without having to also set up proxy light entities using Template lights or Switch as X.
