This goes across AppDaemon, Code Studio Server, and Terminal… but I am trying to get the code server to use python 3.10 since I’m using some match/case
statements. In the bottom of studio server, it shows 3.9 with the interpreter path as /usr/bin/python
However, when I cd
through the terminal, I see different results in /usr/bin/
as opposed to when selecting an interpreter path. I can understand if CS doesn’t show applicable files and interpreter paths… but why is ls -la
not showing the same results? I figured I’d see everything in there.
And if CS is using a different path (for instance, the path within the container and not the host) how do I update it to Python 3.10?
Here are some screenshots:
