Code to list unavailable devices
To assist in my maintenance of a remote installation, I would like a dashboard panel that lists all the devices that are unavailable, preferably sorted according to integration (in my case Tuya, Local Tuya, Sonoff/eWeLink and ZHA).
Has anyone done this?
I did not quite exactly what you are searching for but something very similar.
I have a script written in pyscript that checks for unavailable devices every 30 minutes and uses persistent notifications to notify me when it finds any. It’s quick and dirty and can be improved, but it does its job well enough.
It basically works by getting a list of all devices from the device registry (the huge advantage of pyscript compared to other solutions like AppDaemon or Node Red is, that pyscript allows you to access internal APIs of home assistant like the device registry) and then checking all entities associated with a device. When all entities are in state “unavailable” I then assume that the whole device is unavailable.
 ignore_devices = [
     # Add ids of devices to be ignored here
 ignore_entities = [
     # Add entities whose devices should be ignored here
 CHECKER_ID = "pyscript.device_availability_checker"
 from homeassistant.helpers import entity_registry as erm
 from homeassistant.helpers import device_registry as drm
 from homeassistant.const import STATE_UNAVAILABLE
 @time_trigger('cron(*/30 * * * *)')
 def device_availability_checker_cron():
     er = erm.async_get(hass)
     dr = drm.async_get(hass)
     unavailable_devices = {}
     unavailable_since = {}
     # Iterate over all devices and check whether they are unavailable
     # A device is supposed to be unavailable if all related entities are in
     # state "unavailable"
     for d in dr.devices:
         if d in ignore_devices:
             continue
         unavailable = False
         since = None
         for e in erm.async_entries_for_device(er, d):
             if e.entity_id in ignore_entities:
                 unavailable = False
                 break
             elif hass.states.is_state(e.entity_id, STATE_UNAVAILABLE):
                 unavailable  = True
                 since = hass.states.get(e.entity_id).last_changed
             else:
                 unavailable = False
                 break
         if unavailable:
             unavailable_devices[d] = dr.async_get(d)
             unavailable_since[d] = since
     notifs = []
     devices = {}
     # Iterate over all unavailable devices and construct notification text
     # for a persistent_notification
     for k, d in unavailable_devices.items():
         manufacturer = d.manufacturer
         model = d.model
         text = f'- {d.name}'
         desc = ""
         if model is not None:
             desc += model
         if manufacturer is not None:
             if desc != "":
                 desc += f" [{manufacturer}]"
             else:
                 desc += manufacturer
         if desc != "":
             text += "\n    - " + desc
         text += f"\n    - Since: {unavailable_since[k]}"
         text += f"\n    - ID: {d.id}"
         devices[k] = {
             "name": d.name,
             "manufacturer": manufacturer,
             "model": model,
             "since": unavailable_since[k]
         notifs.append(text)
     # Show a persistent notification or dismiss an old one if there is nothing
     # to show
     ntext = "\n".join(notifs)
     if ntext != "":
         hass.services.async_call("persistent_notification", "create", {
             "notification_id": "device_availability_warning",
             "title": "List of Unavailable Devices",
             "message": ntext
         }, False)
     else:
         hass.services.async_call("persistent_notification", "dismiss", {
         }, False)
     state.set(CHECKER_ID, len(devices), devices = devices)
 @time_trigger('startup')
 def device_availability_checker_startup_trigger():
     log.info("device_availability_checker.startup_trigger()")
     task.sleep(60)
Hi
Nice to get this done with pyscript. I saw some opportunities to improve the code,
  • Some devices like esphome have a binary sensor of connection type. Those remain available and need to be ignored:
  • Some integrations extend existing devices with extra entities. Most will become unavailable as well, except for example powercalc entity’s. Those need to be ignored as well
  • the name field is not always used. Use either the user given name or the name
  • adding the owning integration to the info
Below an extended version that takes these corner cases also into account:
ignore_devices = [
ignore_entities = [
extend_integrations = [
     # Add integration whose entities are added to devices and therefor to be ignored
     "powercalc"]
             continue
         unavailable = False
         since = None
                 unavailable = False
                 break
                 unavailable  = True
             elif ( # check it is not a connection status entity
                    (e.original_device_class != "connectivity") and
                    # check it is not an entity added by integrations to ignore
                    (e.platform not in extend_integrations)
                 unavailable = False
                 break
         if unavailable:
     notifs = []
     devices = {}
         name = d.name if d.name_by_user is None else d.name_by_user
         model = d.model
         text = f'- {name}'
         integration="unknown"
         entry = hass.config_entries.async_get_entry(entry_id=d.primary_config_entry)
         if entry is not None:
             integration = entry.domain
         desc = ""
             desc += model
             if desc != "":
             else:
         if desc != "":
         text += f"\n    - Integration: {integration}"
         devices[k] = {
             "integration": integration,
             "name": name,
             "model": model,
         notifs.append(text)
     # to show
     if ntext != "":
             "message": ntext
         }, False)
     else:
         }, False)
Note: @matzman666 I realy loved to build further on your code. It solved several obstacles I didn’t know how to tackle them. I wrote a template version in the past. This is much better.
Edit: simplified the code as above
Thank you very much for sharing your script @erkr. This looks exactly like what I need.
How are you running them in/through HA to show the results there?
Hi @Quaternion
Prerequisite to run this script is that you have installed the custom integration pyscript (e.g. via HACS), where you probably have to enable these two options in the config:
  • hass_is_global: true
  • allow_all_imports: true
The script will run autonomously by itself (the examples in the posts above runs every 30 minutes). The script does two things:
  • persistent notifications that list the devices that are unavailable
  • creates a sensor that you can use for e.g. dashboards and/or automations; pyscript.device_availability_checker. The state represents the number of unavaliable devices. An attribute lists the details
Note: In my post above I only improved the detection of the original script, no personal tailoring, in order to stay close to the original script.
Then I tailored it fully to my use case:
  • I don’t want notifications as in my setup as there are always unavailable devices (ie HUE lights and Chromecasts physically turned off) → so I made notifications an option (default=off)
  • Increased the execution rate of the the script to once per minute
  • Changed the purpose of ignore_entities; When evaluating the entities of each device, the state of those entities is ignored, not the whole device!
  • added a test script to evaluate one device in the dev tools
My personalized version of the script:
ignore_devices = [
     # Add ids of devices to be ignored here.
     # The template {{ device_id('entity id') }}  can be used to find device id's
ignore_entities = [
     # Add entities that should be ignored when evaluating their device state
     # Add integrations whose entities are added to devices but can remain available
     "powercalc","nmap_tracker"]
@service(supports_response="only")
def device_availability_test(device_id: str):
     """yaml
description: Test the device_availability_checker result for a specific device
fields:
     device_id:
         description: device id to be tested
         required: true
         default: ''
         example: 2e6ec7645070322e572e1e161306c2f7
         selector:
             text:
     if device_id in ignore_devices:
         return {"result": "ignored device" }
     import json
     result=[]
     for e in erm.async_entries_for_device(er, device_id):
         useForCheck = "Yes"
         if (   # check if entity should be ignored
                (e.original_device_class == "connectivity") or
                (e.platform in extend_integrations) or
                (e.entity_id in ignore_entities)
             useForCheck = "Ignored"
         #log.warning(f"avaliablity test entity {e.entity_id}")
         result.append( {"entity": e.entity_id, "part_of_check": useForCheck, "available": "No" if hass.states.is_state(e.entity_id, STATE_UNAVAILABLE) else "Yes", "platform":e.platform,  "device_class": e.original_device_class} )
     return {"result": result }
@time_trigger('cron(* * * * *)')
def device_availability_checker(doNotify=False):
     # state "unavailable". Except some added entities by other integrations, and connectivity types
             continue
         unavailable = False
         since = None
                 continue
                 unavailable  = True
             else:
                 unavailable = False
                 break
         if unavailable:
     notifs = []
     devices = {}
         model = d.model
         area = d.area_id or ""
         #ids = d.identifiers
         #if ids is not None and len(ids):
         #    integration = str(list(ids)[0][0])
         if doNotify:
             text = f'- {name}'
             desc = ""
                 desc += model
                 if desc != "":
                 else:
             if desc != "":
             if area is not None:
                 text += f"\n    - Area: {area}"
             notifs.append(text)
         devices[k] = {
             "area": area,
             "name": name,
             "model": model,
     if doNotify:
         # to show
         if ntext != "":
                 "title": f"List of {len(devices)} Unavailable Devices",
                 "message": ntext
             }, False)
         else:
             }, False)
I created a straight forward dashboard to display them. I used a combi of the mark down and card custom:auto-entities to list the devices. Further I styled the card using card_mod (you can safely remove that ) and used the custom relative_time_plus template to display how long devices are unavailable. You optionally can use the standard available relative_time instead. All these custom items can be installed via HACS.
Note: In this card you can tap on a device to open the device page!
YAML of my card
    type: custom:auto-entities
    card:
      type: entities
      card_mod:
        style: |
          :host {
            --ha-card-border-width: 0px;
          .card-content {
           margin-left: -50px;
    filter:
      template: >
        {%- set devlist =
        state_attr('pyscript.device_availability_checker','devices') or [] %}
        {%- set ns=namespace(rows=[]) -%} {%- from 'relative_time_plus.jinja'
        import relative_time_plus -%} {%- for k in devlist -%}
            {%- set info=devlist[k] -%}
            {%- set sec_info = 'Area:'~info.area~', Mdl:'~info.model  -%}
            {%- set entry = {
              'type': 'custom:template-entity-row',
              'name': info.integration~': '~info.name,
              'state': relative_time_plus(info.since,abbr=true),
              'secondary': sec_info,
              'since': info.since.timestamp(),
              'tap_action': {
                  'action': 'navigate',
                  'navigation_path': '/config/devices/device/'~k },
            {%- set ns.rows= ns.rows + [entry] -%}
        {%- endfor -%}
        {{ ns.rows | sort(attribute='since', reverse = True)}}
      include: []
      exclude: []
    sort:
      method: none
Thank you so much @erkr for taking your time to share all of this, including the detailed explanation.
It works like a charm on my setup and I have been trying exactly to do this through many other options for a while :pray:
