☕ Coffee machine switch automation (Schedule-based or Wattage Detection)
Tired of waiting for your espresso machine to heat up in the morning? Automate it with this blueprint with some additional smart features! :hot_beverage::high_voltage:
Version: 1.1 :fire:
Requirements
  • Home Assistant
  • A smart switch to control your coffee machine
  • (Optional) A power monitoring plug for wattage-based detection
:newspaper: The Automation Process:
Trigger:
  • Schedule-based Activation: Turn on your coffee machine at scheduled times.
  • Manual Trigger Option: Enable on-demand use by manually turning on the coffee machine.
Warmup Detection:
  • Time-based Mode: Set a fixed duration for the coffee machine to warm up.
  • Wattage-based Mode: Monitor power consumption to detect when the machine is warmed up and ready to brew.
Notifications:
  • First Notification: Receive a message when the coffee machine is ready to use.
  • Second Notification: Get a reminder before the machine turns off.
  • Final Notification: Last chance alert before automatic shutdown.
Manual Shutoff Detection:
  • Detect when the coffee machine is manually turned off and stop the automation.
Thanks for your blueprint, it fits my use case pretty well. However, I think I noticed a small mistake.
The description asks to limit the sum helper to 7, but in my automation this fails because it tries to set a much higher value. It seems to work without the limit.
@Zaunei I messed up the description of the helpers. I updated the code on github.
Let me know if you have any other additions.
The logic is fairly simple:
The automation adds 1 to the count helper until it reaches 6. At 7 it resets the helper.
When count is 6 it calculates the avarage of the sum helper (which added 6 readings of the wattage) to check if the avarage is below the threshold. If below the threshold it continues the rest of the automation
Hi there,
thanks for sharing your code. I use it and I works almost perfect. The only thing that is missing is a “No Water” or error detection.
My espresso machine is refilling the boilers after turning on power. If there is not enough water left in the water tank it will show “water needs” and will not heat up. Is there a possibility to check for power consumption within the first minutes and if it’s too low, send a message to refill water.
