Coffee Maker Recommendations
DeLonghi, as reported in the DeLonghi integration, is controlled via Bluetooth, just like the newly created integration for the Jura E8, which the author recently published. In the philips 5400 coffee machine, water drainage is implemented and this is much simpler than in the DeLonghi and Jura, although for the DeLonghi and Jura, if desired, you can also come up with water drainage. You can watch a video of how water drainage works in a Philips 5400 coffee machine, as well as a video from the author of the Jura E8 integration for Home Assistant. Speech on video in Russian
Has anyone figured out how to skip the water cleaning cycle, it is probably the most annoying thing about Delonghi Eletta Explore. If I can’t figure this out, I am probably going to return the thing.
