Cointra Oasis Tech and Ferroli EGEA Tech
I’ve created a custom Home Assistant integration for Cointra Oasis Tech and Ferroli EGEA Tech aerothermal domestic hot water (DHW) systems.
It read temperatures, operating modes and other system parameters directly into Home Assistant.
The integration uses the same Ferroli cloud API as the Ferroli Home / Four Solid mobile app.
It’s currently read-only. It doesn’t send commands or attempt to change any settings or schedules.
I’ve only tested it on my own Cointra Oasis Tech 200 HT, so I’d love to hear from anyone with one of these systems who’s willing to try it, particularly other models or firmware versions.
I’d also appreciate feedback on adding controls in the future. What would you like to be able to change from Home Assistant?
Temperature setpoints, operating modes, schedules?
GitHub:
Installation (Home Assistant 2026.11+):
  1. Open Settings → Marketplace.
  2. Select Custom repositories from the three-dot menu.
  3. Enter the GitHub repository URL and select Integration.
  4. Install Cointra Oasis Tech.
  5. Go to Settings → Devices & Services → Add Integration and select Cointra Oasis Tech.
Any testing, feedback or suggestions would be very welcome.
