Hi Atitej, that’s exactly what I was looking for as well. The other explained solution above is great but is not taking the expiration of the token in account. I have been looking to the AppDeamon integration to get python support. Being still too fresh in Home Assistant, I still need to find my way.
Nevertheless, I have also found: GitHub - lechk82/solarman-mqtt: Send Solarman Smart PV platform metrics (W/kWh) to MQTT which looks to be a solution as well
Hello All.
I managed to setup Solarman via API, is working but still is using the cloud, I am not a big fan of cloud services.
I found a way to obtain data from the logger via a curl command:
curl -s -u admin:admin http://10.0.0.70/status.html | grep -E "\webdata_now_p(\s|$)" | cut -d'"' -f 2
And if you want to get all the data from the logger here are the variables you need to grep:
</script>\r\n<script type="text/javascript">\r\
nvar webdata_sn = "I0120C007166";\r\
nvar webdata_msvn = "V2.41.76";\r\
nvar webdata_ssvn = "V2.41.76";\r\
nvar webdata_pv_type = "";\r\
nvar webdata_rate_p = "";\r\
nvar webdata_now_p = "1175";\r\
nvar webdata_today_e = "9.92";\r\
nvar webdata_total_e = "108.3";\r\
nvar webdata_alarm = "";\r\
nvar webdata_utime = "0";\r\
nvar cover_mid = "1753292631";\r\
nvar cover_ver = "LSW3_14_8401_1.17";\r\
nvar cover_wmode = "APSTA";\r\
nvar cover_ap_ssid = "AP_1753292631";\r\
nvar cover_ap_ip = "10.10.100.254";\r\
nvar cover_ap_mac = "30:EA:E7:36:5F:0C";\r\
nvar cover_sta_ssid = "Home";\r\
nvar cover_sta_rssi = "100%";\r\
nvar cover_sta_ip = "10.0.0.70";\r\
nvar cover_sta_mac = "34:EA:E7:36:5F:0C";\r\
nvar status_a = "1";\r\
nvar status_b = "0";\r\
nvar status_c = "0";\r\n\r\
Is any way to create a sensor using curl and add this data to HA.
Was so simple:
- platform: command_line
command: curl -s -u admin:admin http://10.0.0.70/status.html | grep -E "\webdata_now_p(\s|$)" | cut -d'"' -f 2
unit_of_measurement: 'W'
scan_interval: 10
command: curl -s -u admin:admin http://10.0.0.70/status.html | grep -E "\webdata_total_e(\s|$)" | cut -d'"' -f 2
unit_of_measurement: 'kWh'
scan_interval: 60
command: curl -s -u admin:admin http://10.0.0.70/status.html | grep -E "\webdata_today_e(\s|$)" | cut -d'"' -f 2
scan_interval: 60
Just use quotation marks around stationId and inverterId like “stationId”: “1******”
Can someone help me please. I modified configuration.yaml as shown on the top of this tread:
Solarman API
- platform: rest
resource: https://api.solarmanpv.com/account/v1.0/token?appId=xxxxxxxxxxxxx&language=en&=
method: POST
name: "Total AC Output Power (Active)"
scan_interval: 60
headers:
Authorization: Bearer xxxxxxxxxxxxx
Content-Type: application/json
payload: '{"deviceSn":"SF4xxxxxxxx"}'
value_template: "{{ value_json.dataList[20].value }}"
I know that my credentials and the data of the inverter are OK, getting proper json information on JSON Path Finder
But in the HA entity I see no data, just “Unknown”:
What am I doing wrong?
Awesome; this indeed prevents to need to get (and update) the access token and gives a much higher update frequency of the sensor data (even faster than shown directly at solarman.com). LIKE!
Is this last_reset updated?
Hello all,
After I managed to get the information from the logger directly I have another problem.
The energy dashboard has an issue when is showing the solar consumed energy , but the problem is very strange, energy dashboard is showing much bigger values for solar consumed energy but only for the 08:00 to 09:00 hour and from 09:00 to 10:00.
For example:
30.03.2022
29.03.2022
28.09.2022
In grafana I have the correct values:
30.03.2022
also the value is almost the same on PV cloud:
Dos some one have this issue? Or some one have any idea where is the problem.
command: curl -s -u admin:admin http://10.0.0.50/status.html | grep -E "\webdata_today_e(\s|$)" | cut -d'"' -f 2
scan_interval: 60
template:
- sensor:
- name: "energy_production_today"
state: "{{ states('sensor.solar_energy_today')}}"
device_class: energy
state_class: total_increasing
unit_of_measurement: "kWh"
Hi, great idea!
I have accessed from my local network and I can see the data of the inverter but all the values related to consumption appear at 0 W.
From the Solarman API I can get the data correctly but with some delay, that’s why I wanted to access it locally.
Does anyone know why the values don’t appear?
Anyone collected station historical data? item 4.3 from solarman API guide.
I’m interested in irradiation information.
This worked perfectly fine with me, Thanks
Hi there,
You can solve this issue by using the total solar power. For now this is the most reliable way for cumulative value.
This is my config
configuration.yaml
command: curl -s -u admin:admin http://*****/status.html | grep -E "\webdata_now_p(\s|$)" | cut -d'"' -f 2
scan_interval: 10
command: curl -s -u admin:admin http://******/status.html | grep -E "\webdata_total_e(\s|$)" | cut -d'"' -f 2
scan_interval: 60
command: curl -s -u admin:admin http://*****/status.html | grep -E "\webdata_today_e(\s|$)" | cut -d'"' -f 2
scan_interval: 60
template.yaml
- sensor:
## Solarman local logger
- name: "solarmanlocal_production_daily"
state: "{{ states('sensor.solarmanlocal_power_solar_total')}}"
unit_of_measurement: kWh
unique_id: solarmanlocal_production_daily
Next restart home assistant and choose solarmanlocal_production_daily as the desired meter for solardashboard.
I think it is still not working properly, indeed between specific time the value is higher than expected…
Hi there, got it working now! Please refer to my previous config!
I dont know if its a difference between Solarman and Trannergy or just me, but I couldn’t get the status.html working for my Trannergy Inverter. I did however found the /js/status.js script which contains also the (raw) values. I have the feeling it can be done nicer, but this is what I got it to work with on my Trannergy Inverter:
Current Power (in W):
curl -s http://x.x.x.x/js/status.js | grep -o '<Inverter serial number>.*\";' | cut -d',' -f 6
Yield today (in kWh):
echo "scale=2; $(curl -s http://x.x.x.x/js/status.js | grep -o '<Inverter serial number>.*\";' | cut -d',' -f 7)/100" | bc
Needed to divide the value by 100 and include 2 decimals to get it correct from the raw value.
Total yield (in kWh):
echo "scale=1; $(curl -s http://x.x.x.x/js/status.js | grep -o '<Inverter serial number>.*\";' | cut -d',' -f 8)/10" | bc
Needed to divide the value by 10 and include 1 decimal to get it correct from the raw value.
Also notice that you don’t need to authenticate to access the js file.
Hello.
My configuration still doesn’t work…I still have the initial configuration, where it was working fine…
Now what do I need to change to get the values back?
Alexandre Oiveira
So after a lot of fiddling I managed to get the Solarman-MQTT script working and sending data from my inverter to HA. I have, however, fallen at the last hurdle - I cannot work out how to use the sensor data in the Energy dashboard!
I have one station with 2 inverters - a main hybrid inverter with battery and a smaller second inverter. The station reports total power and grid power, but if I am using solar alone the grid power value is unavailable, and value can be negative (e.g. battery discharge).
Can anyone post an example of a working setup using the values from the API in the energy dashboard? Which sensors do you use, and are any templates required to get the data into the correct format? Thanks!
Hello people.
Is anyone able to generate the token? I’m not getting it anymore, has anything changed? Did I miss something? I’ve been getting this message: “msg”: “appId insufficient allowance”.
If anyone has any tips I would appreciate it.
Hi, Yes had the same issue. You should e-mail solarman with this exact message. They can and will increase your allowance.
I switched however to the integration from Solarman and now I don’t have to use MQTT anymore.
What integration you are using now?
