Hey,
I have been working on a custom integration to support Cololight devices in Home Assistant.
Custom integration, along with documentation, can be found here .
Supported devices include:
Cololight Hexagon
Cololight LED Strip
Commands to the devices are all over UDP, keeping the taffic local on the network.
Also created a python pycololight library, which is used to send commands to the devices.
Feedback always welcome
I’ve been using this for a couple weeks. Works 1000% better than the native app. Thank you
JPvHofe
(JVH)
January 8, 2023, 9:20pm
4
Hi there,
I like this integration. Is there a way to use the effect modes from the documentation?
Hey @JPvHofe ,
Are you able to explain a little more?
Which “effect modes from the documentation” are you referring to?
Machuca
(Miguel Angel)
March 17, 2024, 9:47pm
7
Hi! I am trying to pair my cololight but I need a code with the format XXX-XX-XXX. where can i get it?
Thank you so much!
Hi @Machuca ,
There shouldn’t be any need for a code.
When adding a device, you only need to provide host (IP address), and a name for the device in Home Assistant.
Machuca
(Miguel Angel)
March 25, 2024, 5:57pm
10
When I try to add it, I see this message. Sorry, it is in Spanish
It looks like you’re trying to add the device via HomeKit integration.
This is a custom integration that needs to be installed, and doesn’t operate via HomeKit. You can follow one of the installation methods to add it to Home Assistant.
Machuca
(Miguel Angel)
March 27, 2024, 5:04pm
12
I got it!
Thank you so much
