Good Morning,
I need to attribute a color based on to the state below:
- entity: sensor.wcf_thermo_automation_last_triggered
type: “custom:secondaryinfo-entity-row”
secondary_info: "[[ if(binary_sensor.waterleak_ID == on, ‘Wet’, ‘Dry’) ]]"
How can i add also a text color “red” or “green” to Wet or Dry ?
Thanks a lot in advance
regards
Gianluca
I had a similar usecase. I wanted to change the icon color based on state.
I used https://github.com/thomasloven/lovelace-card-mod
And this is my config:
- entity: sensor.travel_time_home_from_work_here
style: |
:host {
--paper-item-icon-color:
{% if states(config.entity) | float < state_attr(config.entity, 'duration') | float * 1.1 %}
green;
{% elif states(config.entity) | float < state_attr(config.entity, 'duration') | float * 1.3 %}
orange;
{% else %}
red;
{% endif %}
I hope this is a start in the right direction for you
