I have installed a few of these lights - connected to a Wemo Light Switch
http://www.australiansunenergy.com.au/shop/led-lighting/shop-fitting-lighting/residetial-fixed-down-lights/fixed-switchable-colour-10w-led-dimmable-downlight/
Essentially you turn the light on it goes to Day light color, switch off then on it goes Warm White color, switch off on again it goes to a natural color.
I have the Wemo controlled by Hassio and it can switch on and off no problems.
What I would like is a single command to change the light color, that i can control via Google Home ( I have Google HA this working for my Hassio set up).
Something like “hey google change light color” and it would turn the light off then on again changing the light color.
A toggle in Hassio that when toggled would turn light off then on (changing color) but go back to the off state so that it could be run again - to change the color again
I have large Hassio setup, but are really only now trying to add smarts through Automations so a bit of a noob with the ways to do this.
It would be a seperate switch than the on/off switch already in Hassio to control the light
thanks in advance
