I have a couple of color changing smart bulbs that I can control FULLY via the Tuya app. I have them setup within HA via the Tuya account in my config.yaml file as well as local control using their Device ID & Local Key (this is the avenue I prefer). Under State in HA 1 bulb says 3 supported_features and the other 41. So I’ve worked out 1 supports Brightness + Color_Temp and the other supports Brightness + Flash + Transition. Even though I can adjust everything via the app and via Alexa using the Tuya Account + Skill, Does it mean I cannot adjust the RGB colors using Node-Red no matter what I do.
If so can anyone recommend some cheap bulbs that support all the features required to do that
