Inspired by nwithan8’s script, I wanted a script that allowed to define random time bounds and easy to configure. You just need to import it, configure it, and call it (from an automation for example)
You can define up to 12 colors and brightnesses to cycle through (forward of backward, configurable in automation). For each color, you can define the minimum and maximum time to transition to it and the minimum and maximum time to stay on this color. The script will stop automatically if one of the light it runs on has a color or brightness change from another source (most likely the user).
Note that black colors will be ignored in the cycle
# This script will step through (forwards or backwards) a list of assigned colors for an RGB light entity. It is based on nwithan8 script
# Credit : https://community.home-assistant.io/t/zha-cycle-color-for-light-entity/592956
blueprint:
name: Color cycle light effect
description: >-
A script that cycles a light through different colors with customizable random transition and stay times
domain: script
source_url: https://github.com/flonou/Color-cycle-light-effect/edit/main/color_cycle_light_effect_with_random_times.yaml
input:
light:
description: "The Light entity or Light Group entity to loop through the colors chosen below."
selector:
entity:
domain:
- light
- group
multiple: false
color_1:
description: "Set to black to omit this color."
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_1:
description: "Target Brigtness."
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_1:
name: Minimum Transition Time 1
description: "Minimum time to transition to this color."
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_1:
name: Maximum Transition Time 1
description: "Maximum time to transition to this color."
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_1:
name: Minimum Stay Time 1
description: "Minimum time to stay at this color."
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_1:
name: Maximum Stay Time 1
description: "Maximum time to stay to this color."
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_2:
description: "Set to black to omit this color"
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_2:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_2:
name: Minimum Transition Time 2
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_2:
name: Maximum Transition Time 2
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_2:
name: Minimum Stay Time 2
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_2:
name: Maximum Stay Time 2
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_3:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_3:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_3:
name: Minimum Transition Time 3
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_3:
name: Maximum Transition Time 3
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_3:
name: Minimum Stay Time 3
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_3:
name: Maximum Stay Time 3
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_4:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_4:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_4:
name: Minimum Transition Time 4
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_4:
name: Maximum Transition Time 4
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_4:
name: Minimum Stay Time 4
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_4:
name: Maximum Stay Time 4
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_5:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_5:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_5:
name: Minimum Transition Time 5
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_5:
name: Maximum Transition Time 5
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_5:
name: Minimum Stay Time 5
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_5:
name: Maximum Stay Time 5
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_6:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_6:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_6:
name: Minimum Transition Time 6
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_6:
name: Maximum Transition Time 6
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_6:
name: Minimum Stay Time 6
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_6:
name: Maximum Stay Time 6
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_7:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_7:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_7:
name: Minimum Transition Time 7
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_7:
name: Maximum Transition Time 7
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_7:
name: Minimum Stay Time 7
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_7:
name: Maximum Stay Time 7
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_8:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_8:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_8:
name: Minimum Transition Time 8
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_8:
name: Maximum Transition Time 8
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_8:
name: Minimum Stay Time 8
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_8:
name: Maximum Stay Time 8
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_9:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_9:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_9:
name: Minimum Transition Time 9
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_9:
name: Maximum Transition Time 9
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_9:
name: Minimum Stay Time 9
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_9:
name: Maximum Stay Time 9
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_10:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_10:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_10:
name: Minimum Transition Time 10
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_10:
name: Maximum Transition Time 10
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_10:
name: Minimum Stay Time 10
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_10:
name: Maximum Stay Time 10
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_11:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_11:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_11:
name: Minimum Transition Time 11
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_11:
name: Maximum Transition Time 11
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_11:
name: Minimum Stay Time 11
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_11:
name: Maximum Stay Time 11
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
color_12:
default:
- 0
- 0
- 0
selector:
color_rgb: {}
brightness_12:
default: 254
selector:
number:
min: 0
max: 254
min_trans_time_12:
name: Minimum Transition Time 12
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
max_trans_time_12:
name: Maximum Transition Time 12
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 1
min_stay_time_12:
name: Minimum Stay Time 12
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
max_stay_time_12:
name: Maximum Stay Time 12
selector:
duration: {}
default:
hours: 0
minutes: 0
seconds: 0
# Only single, otherwise could flood with attempts
mode: single
fields:
decrement:
description: Go backwards instead of forward in the color list
required: true
selector:
boolean:
variables:
light: !input light
color_rgbs:
- !input "color_1"
- !input "color_2"
- !input "color_3"
- !input "color_4"
- !input "color_5"
- !input "color_6"
- !input "color_7"
- !input "color_8"
- !input "color_9"
- !input "color_10"
- !input "color_11"
- !input "color_12"
brightnesses:
- !input "brightness_1"
- !input "brightness_2"
- !input "brightness_3"
- !input "brightness_4"
- !input "brightness_5"
- !input "brightness_6"
- !input "brightness_7"
- !input "brightness_8"
- !input "brightness_9"
- !input "brightness_10"
- !input "brightness_11"
- !input "brightness_12"
min_transition_times:
- !input min_trans_time_1
- !input min_trans_time_2
- !input min_trans_time_3
- !input min_trans_time_4
- !input min_trans_time_5
- !input min_trans_time_6
- !input min_trans_time_7
- !input min_trans_time_8
- !input min_trans_time_9
- !input min_trans_time_10
- !input min_trans_time_11
- !input min_trans_time_12
max_transition_times:
- !input max_trans_time_1
- !input max_trans_time_2
- !input max_trans_time_3
- !input max_trans_time_4
- !input max_trans_time_5
- !input max_trans_time_6
- !input max_trans_time_7
- !input max_trans_time_8
- !input max_trans_time_9
- !input max_trans_time_10
- !input max_trans_time_11
- !input max_trans_time_12
min_stay_times:
- !input min_stay_time_1
- !input min_stay_time_2
- !input min_stay_time_3
- !input min_stay_time_4
- !input min_stay_time_5
- !input min_stay_time_6
- !input min_stay_time_7
- !input min_stay_time_8
- !input min_stay_time_9
- !input min_stay_time_10
- !input min_stay_time_11
- !input min_stay_time_12
max_stay_times:
- !input max_stay_time_1
- !input max_stay_time_2
- !input max_stay_time_3
- !input max_stay_time_4
- !input max_stay_time_5
- !input max_stay_time_6
- !input max_stay_time_7
- !input max_stay_time_8
- !input max_stay_time_9
- !input max_stay_time_10
- !input max_stay_time_11
- !input max_stay_time_12
# remove invalid (black) RGB values
valid_color_rgbs: >-
{%- set data = namespace(entries=[]) -%}
{%- for color_rgb in color_rgbs -%}
{%- if color_rgb != [0,0,0] -%}
{%- set data.entries = data.entries + [color_rgb] -%}
{%- endif -%}
{%- endfor -%}
{{ data.entries }}
color_count: "{{ valid_color_rgbs | length}}"
# Lights to interact with
lights_to_change: "{{
expand(light)
| selectattr('domain', 'eq', 'light')
| map(attribute='entity_id')
| list
sequence:
- repeat:
sequence:
- variables:
# Next color index to change to.
i_next: >
{% set ns = 0 %}
{% if decrement %}
{% set ns = -repeat.index % color_count %}
{% else %}
{% set ns = repeat.index % color_count %}
{% endif %}
{{ ns }}
color_rgb_next: '{{ color_rgbs[i_next] }}'
brightness_next: '{{ brightnesses[i_next] }}'
min_transition_seconds: "{{ ((min_transition_times[i_next].hours)*60*60) + ((min_transition_times[i_next].minutes)*60) + min_transition_times[i_next].seconds }}"
max_transition_seconds: "{{ ((max_transition_times[i_next].hours)*60*60) + ((max_transition_times[i_next].minutes)*60) + max_transition_times[i_next].seconds }}"
transition_time: "{{ range(min_transition_seconds, max_transition_seconds+1) | random }}"
min_stay_seconds: "{{ ((min_stay_times[i_next].hours)*60*60) + ((min_stay_times[i_next].minutes)*60) + min_stay_times[i_next].seconds }}"
max_stay_seconds: "{{ ((max_stay_times[i_next].hours)*60*60) + ((max_stay_times[i_next].minutes)*60) + max_stay_times[i_next].seconds }}"
stay_time: "{{ range(min_stay_seconds, max_stay_seconds+1) | random }}"
- service: light.turn_on
entity_id: "{{ lights_to_change }}"
rgb_color: "{{ color_rgb_next }}"
brightness: "{{ brightness_next }}"
transition: "{{ transition_time }}"
# The target color might differ from the command. Recover the target color of the light to compare against it later
- variables:
color_rgb_nexts: >
{% set tmpArray = namespace(color_rgb_nexts=[]) %}
{% for light_to_change in lights_to_change %}
{% set tmpArray.color_rgb_nexts = tmpArray.color_rgb_nexts + [state_attr(light_to_change, 'rgb_color')] %}
{% endfor %}
{{ tmpArray.color_rgb_nexts }}
brightnesses_next: >
{% set tmpArray = namespace(brightnesses_next=[]) %}
{% set tmpArray.brightnesses_next = tmpArray.brightnesses_next + [state_attr(light_to_change, 'brightness')] %}
{% endfor %}
{{ tmpArray.brightnesses_next }}
# transition
- delay: "{{ transition_time }}"
# stay
- delay: "{{ stay_time }}"
- variables:
# Means a light target color has been changed elsewhere
mustExit: >
{% set ns = namespace(mustExit=false) %}
{% for light in lights_to_change if not ns.mustExit %}
{% if not is_state_attr(lights_to_change[loop.index0], 'rgb_color', color_rgb_nexts[loop.index0]) %}
{% set ns.mustExit = true %}
{% endif %}
{% if not is_state_attr(lights_to_change[loop.index0], 'brightness', brightnesses_next[loop.index0]) %}
{% endif %}
{% endfor %}
{{ ns.mustExit }}
# break the loop. Until cannot access the local mustExit variable
- if:
condition: template
value_template: "{{ mustExit }}"
then:
- stop: "Stop running the loop"
# this will never be true because of strange variable scope
until: "{{ mustExit }}"
