I have this code but the color does not change on the value. What am i doing wrong?
input_select.2025_knoppenkeuze is an helper with 5 value’s, 1,2,3,4,0. On every value i like to have the button another color. There are 4 buttons to change this value.
type: tile
entity: input_select.2025_knoppenkeuze
icon: mdi:lightbulb-on-40
show_entity_picture: false
hide_state: true
vertical: true
layout_options:
grid_columns: 2
grid_rows: 2
tap_action:
action: perform-action
perform_action: input_select.select_option
entity_id: input_select.2025_knoppenkeuze
option: "1"
icon_tap_action:
action: none
color: |
{% if is_state('input_select.2025_knoppenkeuze') == "1" %}
green
{% else %}
red
{% endif %}
Templates not supported by Tile card. You will have to use card-mod.
Thnx, but that also is not working. it seems i do not get the value of the helper. I don’t see what i am doing wrong
type: tile
hide_state: true
vertical: true
layout_options:
grid_columns: 2
grid_rows: 2
tap_action:
option: verlichting
icon_tap_action:
action: none
card_mod:
style: |
{% if states(entity) == "verlichting" %}
ha-card {
--primary-text-color: red;
--tile-color: red !important;
{% else %}
ha-card {
--primary-text-color: blue;
--tile-color: blue !important;
{% endif %}
thephantom:
states(entity)
try config.entity
(have not checked other code)
to style the icon color on a tile you need to use card_mod with :
style: |
ha-tile-icon {
--tile-color:
{% if is_state(config.entity,'on') %} var(--alert-color)
{% else %} var(--ok-color)
{% endif %};
ofc adapt your template to suit your demands
i need
if option “verlichting” red
if option 2 green
if option 3 blue
if option 4 purple
if option 0 gray
so?
make the template do what you ‘need’
but first test with a direct color
style: |
ha-tile-icon {
--tile-color: green;
btw, are you sure that input_select has the correct options? seems you’re mixing various properties there, using numbers and a state string
