Color LED's using partition
I have 2 partitions for a LED WS8212 strip which works just fine as long as you like white LED’s.
I would like to make one partition red and the other green. How do I go about this?
light:
- platform: neopixelbus
  type: GRB
  pin: GPIO3
  num_leds: 32
  variant: WS2812
  method: ESP8266_DMA
- platform: partition
  name: "Partition Light 1"
  segments:
    # Use first 10 LEDs from the light with ID light_1
    - id: light_1
      to: 3
  name: "Partition Light 2"
  segments:
    # Use LEDs 11-20 from the light with ID light_1
    - id: light_1
      to: 8
Do the lights in HA not show up with a colour wheel?
Also, please check the documentation which recommends to add internal: true to the original light, to avoid interference with the partitions.
I can get color using other methods:
light:
   type: GRB
   pin: GPIO3
   num_leds: 32
   variant: WS2812
   method: ESP8266_DMA
   on_turn_on:
    - light.addressable_set:
       range_from: 0
       range_to: 32
       red: 100%
       green: 0%
       blue: 100%
But not with partitions.
And, pretty sure that internal: true is only used with effects: which I have not been able to get to work.
You set the neopixelbus component to internal so that this does not show up as a light on its own in HA. Has nothing to do with effects.
That makes sense. Thank you!
Good Evening, i try to write in this old discussion, because i’ve the same problem.
I can see, in home assistant the colour wheel if i click on the Led Stripe Entity, if i click on the partitions entities, i can only switch on and switch off.
I tried to put “internal” the entity linked to the entire led stripe, but nothing has changed.
Have you solved your problem?
Thanks in advance.
If you have a question about something not working and you dont post your config for people to help you, how exactly can anyone help you? Do you just want everyone to make guesses about what the problem is? Maybe someone tricked you and said we’re all mind readers but, it isnt true! We cant read minds or see your config in your computer so, if you dont post it then no one can help you.
Thanks a lot for your answer!
Following you can find the code that i’m using on a Sonoff TX Ultimate with 32 Led Frame.
At the moment, in home assistant, I can change colour only for the “Neo Pixel Light” (colour Wheel).
I would like change colour also for partitions: for example “nightlight”.
Now if i click on the partition entity in HA i can only switch on / off the LED Partition.
If i want to change colour i have to change the “nightlight_color” parameter in EspHome code.
Thanks a lot in advance
substitutions:
  friendly_name: "interruttore-sala-tx"
  relay_count: "3"
  toggle_relay_1_on_touch: "true"
  toggle_relay_2_on_touch: "true"
  toggle_relay_3_on_touch: "true"
  vibra_time: 150ms
  button_on_time: 500ms
  button_brightness: "0.7"
  button_color: "{0,0,100}"
  nightlight_brightness: "0.2"
  nightlight_color: "{80,70,0}"
  touch_brightness: "1"
  touch_color: "{0,100,100}"
  touch_effect: "Scan"
  long_press_brightness: "1"
  long_press_color: "{100,0,0}"
  long_press_effect: ""
  multi_touch_brightness: "1"
  multi_touch_color: "{0,0,0}"
  multi_touch_effect: "Rainbow"
  swipe_left_brightness: "1"
  swipe_left_color: "{0,100,0}"
  swipe_left_effect: ""
  swipe_right_brightness: "1"
  swipe_right_color: "{100,0,70}"
  swipe_right_effect: ""
  relay_1_pin: GPIO18
  relay_2_pin: GPIO17
  relay_3_pin: GPIO27
  relay_4_pin: GPIO23
  vibra_motor_pin: GPIO21
  pa_power_pin: GPIO26
  led_pin: GPIO13
  status_led_pin: GPIO33
  uart_tx_pin: GPIO19
  uart_rx_pin: GPIO22
  audio_lrclk_pin: GPIO4
  audio_bclk_pin: GPIO2
  audio_sdata_pin: GPIO15
  touchpanel_power_pin: GPIO5
esphome:
  friendly_name: ${friendly_name}
  project:
    version: "1.0"
  on_boot:
    priority: -100
    then:
      - binary_sensor.template.publish:
          state: OFF
          state: OFF
          state: OFF
          state: OFF
          state: OFF
          state: OFF
          state: OFF
      - script.execute: refresh_led_default
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
#  hardware_uart: UART2
  level: DEBUG
  logs:
    binary_sensor: INFO
    light: INFO
    script: INFO
    switch: INFO
    tx_ultimate_touch: INFO
    uart_debug: INFO
api:
ota:
  - platform: esphome
    password: XXXXXXXXXXX
wifi:
  ssid: XXXXXXXXX
  password: XXXXXXXXXXXX
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: XXXXXXXX
    # Set this to the IP address of the router. Often ends with .1
    gateway: XXXXXXXXXX
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: XXXXXXXXXX
  ap:
    ssid: ${friendly_name} AP
improv_serial:
captive_portal:
external_components:
#  - source: /config/esphome/my_components
#    components: [tx_ultimate_touch]
  - source:
      type: git
      url: https://github.com/SmartHome-yourself/sonoff-tx-ultimate-for-esphome
      ref: main
globals:
  - id: nightlight_color
    type: int [3]
    restore_value: no
    initial_value: ${nightlight_color}
  - id: button_color
    type: int [3]
    restore_value: no
    initial_value: ${button_color}
  - id: long_press_color
    type: int [3]
    restore_value: no
    initial_value: ${long_press_color}
  - id: multi_touch_color
    type: int [3]
    restore_value: no
    initial_value: ${multi_touch_color}
  - id: swipe_left_color
    type: int [3]
    restore_value: no
    initial_value: ${swipe_left_color}
  - id: swipe_right_color
    type: int [3]
    restore_value: no
    initial_value: ${swipe_right_color}
  - id: touch_color
    type: int [3]
    restore_value: no
    initial_value: ${touch_color}
binary_sensor:
    name: "${friendly_name} Touchfield 1"
    on_press:
      - if:
          condition:
            lambda: "return ${toggle_relay_1_on_touch};"
          then:
            - switch.toggle: relay_1
      - delay: ${button_on_time}
          state: OFF
    name: "${friendly_name} Touchfield 2"
    on_press:
      - if:
          condition:
            lambda: "return ${toggle_relay_2_on_touch};"
          then:
            - switch.toggle: relay_2
          state: OFF
    name: "${friendly_name} Touchfield 3"
    on_press:
      - if:
          condition:
            lambda: "return ${toggle_relay_3_on_touch};"
          then:
            - switch.toggle: relay_3
          state: OFF
    name: "${friendly_name} Swipe left"
    on_press:
          state: OFF
    name: "${friendly_name} Swipe_right"
    on_press:
          state: OFF
    name: "${friendly_name} Multi Touch"
    on_press:
          state: OFF
    name: "${friendly_name} Long Press"
    on_press:
          state: OFF
switch:
  - platform: gpio
    pin: ${relay_1_pin}
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_on:
      then:
    on_turn_off:
      then:
  - platform: gpio
    pin: ${relay_2_pin}
    on_turn_on:
      then:
    on_turn_off:
      then:
#  - platform: gpio
#    id: relay_3
#    name: "${friendly_name} L3"
#    pin: ${relay_3_pin}
#    restore_mode: RESTORE_DEFAULT_OFF
#    on_turn_on:
#      then:
#        - script.execute: refresh_led_default
#    on_turn_off:
#      then:
    id: relay_3          # Corridoio scollegato da Relay
    internal: false
    optimistic: true
    on_turn_on:
      then:
    on_turn_off:
      then:
  - platform: gpio
    pin: ${vibra_motor_pin}
    name: "${friendly_name} Vibration"
    restore_mode: ALWAYS_OFF
    on_turn_on:
      - delay: ${vibra_time}
      - switch.turn_off: vibra
  - platform: gpio
    pin: ${pa_power_pin}
    internal: true
    restore_mode: ALWAYS_ON
  - platform: gpio
    name: "touch panel power"
    pin:
      number: ${touchpanel_power_pin}
      inverted: true
    internal: true
    restore_mode: RESTORE_DEFAULT_ON
#  - platform: template
#    name: "${friendly_name} Nightlight"
#    id: nightlight
#    internal: true
#    optimistic: true
#    on_turn_on:
#      then:
#    on_turn_off:
#      then:
    optimistic: true
    on_turn_on:
      then:
    on_turn_off:
      then:
  - platform: restart
light:
    type: GRB
    variant: WS2812
    pin: ${led_pin}
    num_leds: 32
    name: "${friendly_name} NeoPixel Light"
    default_transition_length: 0s
    effects:
      - addressable_rainbow:
          speed: 30
          width: 8
      - pulse:
          transition_length: 1.4s
          update_interval: 1s
    on_turn_off:
      then:
    name: "LEDs Button right"
    internal: true
    segments:
      - id: leds
        to: 7
      - id: leds
        to: 17
    name: "LEDs Button middle"
    internal: true
    segments:
      - id: leds
        to: 4
      - id: leds
        to: 20
    name: "LEDs Button left"
    internal: true
    segments:
      - id: leds
        to: 1
      - id: leds
        to: 23
    internal: true
    segments:
      - id: leds # perimetro allargato OK - eliminare eventualmente
        to: 30
      - id: leds
        to: 31
      - id: leds
        to: 2
      - id: leds
        to: 5
      - id: leds
        to: 8
        to: 14
      - id: leds #prova effetti parte sotto eliminare eventualmente
        to: 15
        to: 18
        to: 21
        to: 24
    effects:
      - addressable_scan:
          speed: 10
          width: 20
media_player:
  - platform: i2s_audio
    dac_type: external
    i2s_dout_pin: ${audio_sdata_pin}
    i2s_audio_id: audio_i2s
    i2s_comm_fmt: lsb
    mode: mono
i2s_audio:
  i2s_lrclk_pin: ${audio_lrclk_pin}
  i2s_bclk_pin: ${audio_bclk_pin}
uart:
  tx_pin: ${uart_tx_pin}
  rx_pin: ${uart_rx_pin}
  baud_rate: 115200
  data_bits: 8
  stop_bits: 1
  parity: NONE
  debug:
    direction: RX
    dummy_receiver: false
    after:
      timeout: 2s
      bytes: 2048
    sequence:
      - lambda: UARTDebug::log_hex(direction, bytes, ' ');
tx_ultimate_touch:
  uart: my_uart
  on_press:
    - script.execute: led_on_touch
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_press", "Touch Position: %d / State: %d", touch.x, touch.state);
  on_release:
    - script.execute:
        pos: !lambda "return touch.x;"
    - switch.turn_on: vibra
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_release", "Release Position: %d / State: %d", touch.x, touch.state);
  on_swipe_left:
    - script.execute: led_on_swipe_left
        state: ON
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_swipe_left", "Swipe Left Position: %d / State: %d", touch.x, touch.state);
  on_swipe_right:
    - script.execute: led_on_swipe_right
        state: ON
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_swipe_right", "Swipe Right Position: %d / State: %d", touch.x, touch.state);
  on_full_touch_release:
    - script.execute: led_on_full_touch
        state: ON
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_full_touch_release", "Full Touch Release Position: %d / State: %d", touch.x, touch.state);
  on_long_touch_release:
    - script.execute: led_on_long_touch
        state: ON
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_long_touch_release", "Long Touch Release Position: %d / State: %d", touch.x, touch.state);
script:
  - id: refresh_led_default         # SCRIPT PRINCIPALE PER LA GESTIONE DEI LED SU AZIONI.
    mode: restart
    then:
      - light.turn_off: leds_top    # VERIFICARE QUESTA CONDIZIONE
      - if:
          condition:
            lambda: "return (${relay_count}>1 && id(relay_1).state) ;"
          then:
            - script.execute: led_on_button_left
          else:
            - script.execute: led_off_button_left
      - if:
          condition:
            lambda: "return (${relay_count}==3 && id(relay_2).state) || (${relay_count}==1 && id(relay_1).state);"
          then:
            - script.execute: led_on_button_middle
          else:
            - script.execute: led_off_button_middle
      - if:
          condition:
            lambda: "return (${relay_count}==2 && id(relay_2).state) || (${relay_count}==3 && id(relay_3).state);"
          then:
            - script.execute: led_on_button_right
          else:
            - script.execute: led_off_button_right
      - if:
          condition:
            lambda: "return id(nightlight_active).state;"
          then:
            - script.execute: led_on_nightlight
          else:
  - id: led_on_button_left    #DEFINISCE IL COMPORTAMENTO DEI LED DEL BOTTONE SINISTRO ALL'ACCENSIONE
    mode: restart
    then:
      - light.turn_on:
          brightness: ${button_brightness}
          red: !lambda "return id(button_color)[0]/100.0;"
          green: !lambda "return id(button_color)[1]/100.0;"
          blue:  !lambda "return id(button_color)[2]/100.0;"
  - id: led_on_button_middle  #DEFINISCE IL COMPORTAMENTO DEI LED DEL BOTTONE CENTRALE ALL'ACCENSIONE
    mode: restart
    then:
      - light.turn_on:
  - id: led_on_button_right   #DEFINISCE IL COMPORTAMENTO DEI LED DEL BOTTONE DESTRO ALL'ACCENSIONE
    mode: restart
    then:
      - light.turn_on:
  - id: led_off_button_left   #DEFINISCE IL COMPORTAMENTO DEI LED DEL BOTTONE SINISTRO ALLO SPEGNIMENTO
    mode: restart
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                brightness: ${nightlight_brightness}
                red: !lambda "return id(nightlight_color)[0]/100.0;"
                green: !lambda "return id(nightlight_color)[1]/100.0;"
                blue:  !lambda "return id(nightlight_color)[2]/100.0;"
          else:
            - light.turn_off:
  - id: led_off_button_middle   #DEFINISCE IL COMPORTAMENTO DEI LED DEL BOTTONE CENTRALE ALLO SPEGNIMENTO
    mode: restart
    then:
      - if:
          condition:
          then:
            - light.turn_on:
          else:
            - light.turn_off:
  - id: led_off_button_right    #DEFINISCE IL COMPORTAMENTO DEI LED DEL BOTTONE DESTRO ALLO SPEGNIMENTO
    mode: restart
    then:
      - if:
          condition:
          then:
            - light.turn_on:
          else:
            - light.turn_off:
  - id: led_on_nightlight   #DEFINISCE IL COMPORTAMENTO DEI LED DELLA NIGHTLIGHT
    mode: restart
    then:
      - light.turn_on:
#  - id: led_on_release    #DEFINISCE IL COMPORTAMENTO DEI LED QUANDO VIENE RILASCIATO IL TOUCH
#    mode: restart
#    then:
#      - light.turn_off:
#          id: leds_top
  - id: led_on_touch      #DEFINISCE IL COMPORTAMENTO DEI LED DURANTE IL TOUCH
    mode: restart
    then:
      - light.turn_on:
          brightness: ${touch_brightness}
          red: !lambda "return id(touch_color)[0]/100.0;"
          green: !lambda "return id(touch_color)[1]/100.0;"
          blue:  !lambda "return id(touch_color)[2]/100.0;"
          effect: ${touch_effect}
      - delay: 6s
  - id: led_on_swipe_left    #DEFINISCE IL COMPORTAMENTO DEI LED DURANTE LO SWIPE A SINISTRA
    mode: restart
    then:
      - light.turn_on:
          brightness: ${swipe_left_brightness}
          red: !lambda "return id(swipe_left_color)[0]/100.0;"
          green: !lambda "return id(swipe_left_color)[1]/100.0;"
          blue:  !lambda "return id(swipe_left_color)[2]/100.0;"
          effect: ${swipe_left_effect}
  - id: led_on_swipe_right    #DEFINISCE IL COMPORTAMENTO DEI LED DURANTE LO SWIPE A DESTRA
    mode: restart
    then:
      - light.turn_on:
          brightness: ${swipe_right_brightness}
          red: !lambda "return id(swipe_right_color)[0]/100.0;"
          green: !lambda "return id(swipe_right_color)[1]/100.0;"
          blue:  !lambda "return id(swipe_right_color)[2]/100.0;"
          effect: ${swipe_right_effect}
  - id: led_on_full_touch      #DEFINISCE IL COMPORTAMENTO DEI LED DURANTE IL MULTI TOUCH
    mode: restart
    then:
      - light.turn_on:
          brightness: ${multi_touch_brightness}
          red: !lambda "return id(multi_touch_color)[0]/100.0;"
          green: !lambda "return id(multi_touch_color)[1]/100.0;"
          blue:  !lambda "return id(multi_touch_color)[2]/100.0;"
          effect: ${multi_touch_effect}
  - id: led_on_long_touch     #DEFINISCE IL COMPORTAMENTO DEI LED DURANTE IL LONG PRESS
    mode: restart
    then:
      - light.turn_on:
          brightness: ${long_press_brightness}
          red: !lambda "return id(long_press_color)[0]/100.0;"
          green: !lambda "return id(long_press_color)[1]/100.0;"
          blue:  !lambda "return id(long_press_color)[2]/100.0;"
          effect: ${long_press_effect}
  - id: handle_release     # ATTIVA I BINARY SENSOR TOUCHFIELD 1 2 e 3.
    mode: restart
    parameters:
      pos: int
    then:
      - if:
          condition:
            lambda: "return ${relay_count}==1;"
          then:
                state: ON
      - if:
          condition:
            lambda: "return ${relay_count}==2;"
          then:
            - if:
                condition:
                  lambda: "return pos <= 5;"
                then:
                      state: ON
                else:
                      state: ON
      - if:
          condition:
            lambda: "return ${relay_count}==3;"
          then:
            - if:
                condition:
                  lambda: "return pos <= 3;"
                then:
                      state: ON
                else:
                  - if:
                      condition:
                        lambda: "return pos <= 7;"
                      then:
                            state: ON
                      else:
                            state: ON
OK, A couple of things…
When you partition an led strip, that means your turning 1 light into 2 or more controllable lights, right?
I can see that you have no control the partitions because you set them all up to be hidden from the front end in HA.
Some of them arent set up correctly and they may not work well or work at all anyway. You’ve got a bunch of partitions and theres a warning in the documentation about doing that because of high risk you run out of memory.
Each of your problems is because you didn’t read the documentation or configure the partitions how it tells you too.
Like here, that isnt how it tells you to use (internal).
Check the documentation again. Ill help you if you cant figure it out but, every problem you have is from not setting it up like it tells you.
