🧯 Color-Multi-Tool
Custom Template for doing things with colors.
hacs_badge Version Community Forum
GitHub issues GitHub closed issues GitHub contributors
:fire_extinguisher: Color-Multi-Tool
Custom Template for doing things with colors. It started out by wanting a way to get a random color name off of the official color name list. Then I decided it needed a way to pull random rgb, hs, and xy colors as well. I then decided to build the conversions between all the types.
The conversions are derived from HA's own color conversion code with the exception of rgb2hs. Home Assistant uses the built-in python module to do that in core, so I pulled the code for that from another source.
I followed the conversion code as close as I could, but I find that if you convert a color then convert it back, it drifts quite a bit.
I welcome the PR from anyone that can improve any of this code. It is 'functional' but not optimized at this point. In several cases I don't understand the code, I just ported it over, hopefully successfully. PR's are welcome.
Documentation for this Custom Template can be found at:
This requires HomeAssistant version 2023.11.0 or greater due to the use of the list test in the code.
:microbe: TO-DO List
  • HEX conversions
:nut_and_bolt: Installation
Install this in HACS or download the color_multi_tool.jinja. From this repository and place the files into your config\custom_templates directory.
If you cannot see templates in your HACS listing
You may need to enable 'experimental features' mode. To do this find the HACS section of the Home Assistant Integration page. Click on the '>' arrow to bring you to the custom integration page. Then click on configure, and select 'enable experimental features' check box. click submit, then float out and restart the HA server to make sure it takes. When you come back HACS will look slightly different, but the Templates section is now visible and you will be able to select it. At some point in time HACS will update and the new interface and options will be the only available interface.
Other help
Before you report a 'Bug', you need to make sure you have read the accompanying Descriptions on the templates and this README and have followed all the settings required here. This is important because if these instructions are not followed, you will likely have a bad day and be forced to contact me for help. Not that I don't want to help, but personal interaction takes me a while to respond and is generally non-productive.
Another good thing to do before you ask for help is try testing what you have in the Developer Tools Template Tab in Home Assistant. There you can adjust this and that until you figure out the answer to your question yourself. At the end of the color table in the code is the developer code that I use to test everything. If you provide any PR's make sure you load this and test all the things.
Open your Home Assistant instance and show your template developer tools.
Random Color Name
random_name()
This will return one of the official color names recognized by Home Assistant lifted directly from the Home Assistant core github November, 2023 at core/homeassistant/util/color.py at dev · home-assistant/core · GitHub and the Official CSS3 colors from w3.org: CSS Color Module Level 3
Names do not have spaces in them so that we can compare against requests more easily (by removing spaces from the requests as well).
This lets "dark seagreen" and "dark sea green" both match the same color "darkseagreen".
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import random_name %} {{- random_name() -}}
Random xy Color
random_xy()
This will return a CSV string that will convert to a list for a random color in the x,y format.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import random_xy %} {% set _rxy = random_xy().split(",") | list -%} {{ [_rxy[0]|float|round(3),_rxy[1]|float|round(3)] | list}}
REMEMBER: Everything returned from a macro template is a string, so for conventional usage of colors the result needs to be converted to a list as shown in the example above.
Random hs Color
random_hs()
This will return a CSV string that will convert to a list for a random color in the h,s format.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import random_hs %} {% set _rhs = random_hs().split(",") | list -%} {{ [_rhs[0]|float|round(2),_rhs[1]|float|round(2)] | list}}
Random rgb Color
random_rgb()
This will return a CSV string that will convert to a list for a random color in the rgb format.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import random_rgb %} {% set _rrgb = random_rgb().split(",") | list -%} {{ [_rrgb[0]|int(0),_rrgb[1]|int(0),_rrgb[2]|int(0)] | list}}
Return the rgb Number for a Provided Color Name
name2rgb(color_name)
This will return the RGB value for an official color name recognized by Home Assistant lifted directly from the Home Assistant core github November, 2023 at core/homeassistant/util/color.py at dev · home-assistant/core · GitHub and the Official CSS3 colors from w3.org: CSS Color Module Level 3
You have to type in her correct name. The text you send me will be set to no spaces and lower case to match the data as described above.
If the name is not found, it will return "0.0.0", IE black, because then name you provided is not a color.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import name2rgb %} {% set _name2rgb = name2rgb(color_name) %} {{ [_name2rgb[0]|int(0),_name2rgb[1]|int(0),_name2rgb[2]|int(0)] | list}}
Return the Color Name for a Provided rgb Number
rgb2name(range, rgb_formatted_list)
This template will accept a list representing an RGB value plus a range value representing the window size of the 'close enough' color name. It will return the Home Assistant Color name that matches it or is close to it within a +/- range you specify.
  • If you want only an exact match, then set the range to 0.
  • If you think that +10/-10 is close enough, then set the range to 10.
For default the color is set to black [0,0,0] and the range is 0, so it will by give you ['black'] for invalid input.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import rgb2name %} {{ rgb2name(10,rgbl) }}
REMEMBER: Everything returned from a macro template is a string.
Return the dingle Closest Color Name for a Provided rgb Number
rgb_bestname(rgbl)
This will return a string that is the name in the HA table closest to the rgb list provided based on the sum of the squared differences.
One valid color name will be returned.
For default the color is set to black [0,0,0] so it will give you black for invalid input as well.
Code adapted from xalbertoisorna’s gists · GitHub here October, 2025: Kelvin to RGB in python · GitHub
Return the rgb Number that is Complementary to a provided rgb Number
rgb_complement(rgbl)
This will return a CSV string that is the complementary of the rgb list provided. Complementary colors are pairs of colors that, when combined or mixed, cancel each other out by producing a grayscale color like white or black This means that the light waves they produce together comprise all of the visible wavelengths of light. On the color wheel, complementary colors are located directly opposite each other.
Be sure to convert this to a list when you use it on the other end because it arrives as a CSV string.
Code lifted directly from the here October, 2025 at Complementary Colors Generator.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import rgb_bestname %} {{ rgb_bestname(rgbl) }} {% from 'color_multi_tool.jinja' import rgb_complement %} {% set _rgb_c = rgb_complement(rgbl).split(",") | list %} {{ [_rgb_c[0]|int(0),_rgb_c[1]|int(0),_rgb_c[2]|int(0)] }}
Return the xy Number for a Provided rgb Number
rgb2xy(rgb_formatted_list)
This will return a CSV string that will convert to a list in the x,y format from the rgb list provided.
Code lifted directly from the Home Assistant core github November, 2023 at core/homeassistant/util/color.py at dev · home-assistant/core · GitHub.
Brightness is assumed to be 100%
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import rgb2xy %} {% set _rgb2xy = rgb2xy(rgbl).split(",") | list -%} {{ [_rgb2xy[0]|float|round(3),_rgb2xy[1]|float|round(3)] | list}}
Return the rgb Number for a Provided xy Number
xy2rgb(xy_formatted_list)
This will return a CSV string that will convert to a list in the rgb format from the xy list provided.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import xy2rgb %} {% set _xy2rgb = xy2rgb(xyl).split(",") | list -%} {{ [_xy2rgb[0]|int(0),_xy2rgb[1]|int(0),_xy2rgb[2]|int(0)] | list}}
Return the rgb Number for a Provided hs Number
hs2rgb(hs_formatted_list)
This will return a CSV string that will convert to a list in the rgb format from the hs list provided.
Code adaptation from jdepp236 · GitHub. See #11 (comment)
SAMPLE USAGE: {% from 'color_multi_tool.jinja' import hs2rgb %} {% set _hs2rgb = hs2rgb(hsl).split(",") | list %} {{ [_hs2rgb[0]|int(0),_hs2rgb[1]|int(0),_hs2rgb[2]|int(0)] }}
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import hs2rgb %} {% set _hs2rgb = hs2rgb(hsl).split(",") | list -%} {{ [_hs2rgb[0]|int(0),_hs2rgb[1]|int(0),_hs2rgb[2]|int(0)] | list}}
Return the hs Number for a Provided rgb Number
rgb2hs(rgb_formatted_list)
Code lifted directly from the here November, 2023 at Color Conversion Algorithms.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import rgb2hs %} {% set _rgb2hs = rgb2hs(rgbl).split(",") | list -%} {{[ _rgb2hs[0]|float(0)|round(3),_rgb2hs[1]|float(0)|round(3)] | list}}
Return the xy Number for a Provided hs Number
hs2xy(hs_formatted_list)
This will return a CSV string that will convert to a list in the hs format from the xy list provided.
This converter uses other templates provided in this Custom Jinja Template.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import hs2xy %} {% set _hs2xy = hs2xy(hsl).split(",") | list -%} {{ [_hs2xy[0]|float|round(3),_hs2xy[1]|float|round(3)] | list}}
Return the hs Number for a Provided xy Number
xy2hs(xy_formatted_list)
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import xy2hs %} {% set _xy2hs = xy2hs(xyl).split(",") | list -%} {{ [_xy2hs[0]|float|round(3),_xy2hs[1]|float|round(3)] | list}}
REMEMBER: Everything returned from a macro template is a string, so for conventional usage of colors the result needs to be converted to a list as shown in the example above. list as shown in the example above.
Return all of the color names in the official HA color list
color_list()
This will return all of the official color names recognized by Home Assistant lifted directly from the Home Assistant core github November, 2023 at core/homeassistant/util/color.py at dev · home-assistant/core · GitHub and the Official CSS3 colors from w3.org: CSS Color Module Level 3 Names do not have spaces in them so that we can compare against requests more easily (by removing spaces from the requests as well). This lets "dark seagreen" and "dark sea green" both match the same color "darkseagreen". You also get the RGB color code for each of the color names.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import color_list() %} {{- color_list().split('\n') | list -}}
Return KELVIN Color Temperature for a Provided rgb Number
rgb2k(rgbl)
This will return the Color Temperature Kelvin based on the RGB value provided. Input value will be validated as a list of 3 integers between 0 & 255.
Default output is 0, so if something goes wrong it will return 0.
Converts from RGB to K, algorithm courtesy of Redirecting…. The closest match code and the idea for this method is from: xalbertoisorna’s gists · GitHub October, 2025: Kelvin to RGB in python · GitHub
These numbers were dropped in a table as a lookup and are polled based on a best match formula.
That formula squares the difference for R, G, & B and adds them up, lowest score wins. The table is not continuous, it jumps 100 KELVIN at a time so there are some approximations going on here.
None of this color stuff is exact...
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import rgb2k %} {{ rgb2k([51.255,255]) }}
Return the rgb Number for a Provided KELVIN Color Temperature
k2rgb(colour_temperature)
This will return and RGB list of the corresponding Color Temperature Kelvin value provided.
Value will be validated as a number 1000 thru 40000.
If you want to cheat with Kelvin values outside that range, read the chkK(int) macro for instructionson doing this.
Converts from K to RGB, algorithm courtesy of Redirecting… This jinga adaptation courtesy Didgeridrew
SAMPLE USAGE:
{% set _k2rgb = k2rgb(kl).split(",") | list %} {{ [_k2rgb[0]|int(0),_k2rgb[1]|int(0),_k2rgb[2]|int(0)] }}
Test if a list is a valid KELVIN Color Temperature 500 -> 40,000
chkK(_K)
Is the Kelvin value in the Valid Range? This will test that a number is a valid Kelvin number 500 thru 40'000.
First we need to test that this is a number. Then we check if it 500 thru 40,000. If all that is true return true. If any is not true, return false.
NOTE: If you want to input Kelvin numbers that are out of range, then uncomment the {{- true -}} right before {% endmacro %} so that this only tests for a valid number.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import chkK %} {{ chkK(2000) | bool }}
REMEMBER: This always returns text, so cast to bool on the other end to be certain of the result.
Test if a list is a valid RGB color list
chkRGB(rgb_formatted_list)
This will test a list to make sure it’s a valid RGB color list.
First we need to make sure it’s a list, and that the list has 3 members. Then we need to test that each member is a number, an integer, and between 0 & 255. If all that is true return True. If any is not true, return False. Development credit to @Didgeridrew and @anon60850888 on the Home Assistant Community Forums for help sorting this out.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import chkRGB %} {{ chkRGB([255,165,0]) | bool }}
Test if a list is a valid XY color list
chkXY(xy_formatted_list)
This will test a list to make sure it’s a valid XY color list.
First we need to make sure it’s a list, and that the list has 2 members. Then we need to test that each member is a number, and between 0 & 1. If all that is true return True. If any is not true, return False. Development credit to @123 on the Home Assistant Community Forums for help sorting this out.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import chkXY %} {{ chkXY([0.497,0.472]) | bool }}
Test if a list is a valid HS color list
chkHS(hs_formatted_list)
This will test a list to make sure it’s a valid HS color list.
First we need to make sure it’s a list, and that the list has 2 members. Then we need to test that each member is a number. The first one has to be 0 to 100, the second one has to be 0 to 360. If all that is true return True. If any is not true, return False. Development credit to @123 on the Home Assistant Community Forums for help sorting this out.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import chkHS %} {{ chkHS([38.824,100.0]) | bool }}
Test if a Color name is in the official HA color list
chkNAME(color_name)
Is this color name on the official list? This will test a provided color name to see if it is on the HA color list.
First we need to make sure it’s a string_like variable. Then we test that the string is only lowercase letters to match the HA list. Then we iterate thru the list to make sure it is on the list. If all that is true return true. If any is not true, return false.
SAMPLE USAGE:
{% from 'color_multi_tool.jinja' import chkNAME %} {{ chkNAME('orange') | bool }}
Other Info
Location of this code: GitHub - SirGoodenough/Color-Multi-Tool: Toolbox to work with and convert colors rgb, hs, xy, and Color Name. It will also provide random colors in any format, attempt to match your RGB value to an official color, and test if the color is valid (numbers or name). · GitHub
Home Assistant Community Forum post: 🧯 Color-Multi-Tool
Let me know if you have a suggestion.
If you have any questions, comments or additions be sure to add an issue in the above listed github repo and bring them up on my Discord Server:
:man_juggling:t5: Contact Links or see my other work
What are we Fixing Today Homepage / Website: https://www.WhatAreWeFixing.Today/
Channel Link URL: (WhatAreWeFixingToday): https://bit.ly/WhatAreWeFixingTodaysYT
What are we Fixing Today Facebook page (Sir GoodEnough): https://bit.ly/WhatAreWeFixingTodaybFB
What are we Fixing Today Twitter Account (Sir GoodEnough): https://bit.ly/WhatAreWeFixingTodayTW
Discord Guild: (Sir_Goodenough#9683): WhatAreWeFixingToday?
BluePrint Library: HA_Blueprints/README.md at master · SirGoodenough/HA_Blueprints · GitHub
#WhatAreWeFixingToday
#SirGoodEnough
Disclaimer
:warning: DANGER OF ELECTROCUTION :warning:
If your device connects to mains electricity (AC power) there is danger of electrocution if not installed properly. If you don't know how to install it, please call an electrician (Beware: certain countries prohibit installation without a licensed electrician present). Remember: SAFETY FIRST. It is not worth the risk to yourself, your family and your home if you don't know exactly what you are doing. Never tinker or try to flash a device using the serial programming interface while it is connected to MAINS ELECTRICITY (AC power).
:moai:License Notice:
Just wanted to say that i really appreciate your work here, thanks for making those templates!
Templates are the real shit;)
Bests
@Sir_Goodenough did you ever create a card for this?
NEW Version Today
Nixed a couple of bugs and added 5 more functions…
Enjoy please…
Add 5 Functions Latest
Merged: #15 #16 #17 #18 to close several issues.
Added 5 functions
  • rgb2k(rgbl) rgb to color temp
  • k2rgb(kelvin) color temp to rgb
  • chkK(_K) Check for a valid kelvin 500 to 40000
  • rgb_complement(rgbl) Redurn the complementary RGB
  • rgb_bestname(rgbl) Return the best match color name from an RGB provided
rewrite of hs2rgb
fix chkhs
Closed Issues: #4 #11 #13 #15
