Hello together,
unfortunately I can’t do this alone so I hope You can help me.
I want to do a list with the temperatures and humidity of the rooms. Also I would like to have, when the humidity go above (for example) 60%, the number will be orange and above 70% red.
How You can see on the screenshoot, change the colour isn’t a problem but with “if” I do something wrong but what?
type: entities
entities:
- entity: sensor.temperatur_aussen_temperature
type: custom:multiple-entity-row
secondary_info: last-changed
show_state: false
entities:
- sensor.temperatur_aussen_temperature
- entity: sensor.temperatur_aussen_humidity
styles:
color: >-
[[[ if (states["sensor.temperatur_aussen_humidity"].state != "0")
return "blue"; else return "red"]]]
- entity: sensor.wandthermostat_temperature_2
show_state: false
entities:
styles:
color: red
- entity: sensor.wandthermostat_humidity_2
styles: >-
{% if is_state('sensor.wandthermostat_humidity_2') >= "60") %}
color: orange
{% if is_state('sensor.wandthermostat_humidity_2') >= "70") %}
color: red
{% else %}
color: green
{% endif %}
Thank You,
kamil
