Short and sweet, it’d be great to have an input helper to pick a color. There doesn’t seem to be any (friendly) way to pick a color for anything in HA, unless it’s tied to the color of a light entity… And I’ve recently been finding myself working in some automations that I’d like to use a color, unrelated to the state of any particular light.
Is this possible? Could it happen? Does anybody else see any utility in this?
Where do you want to pick the colour from? When I’m looking for a colour for say a light so I can enter in an automation I generally set the light to a colour I like using the standard colour wheel and then go into the developer tools to grab the RGB value from the entity attributes.
Yes, I’m attempting to create some automations (and probably blueprints) to change the secondary and tertiary colors of a WLED device, since the standard integration only affects the primary color.
I was attempting to do this via a template light, but WLED only reports colors as RGB, and not HS, as a template light requires.
My thinking is that if I could pick a color, independent of the current state of a light, then I could send that value directly.
Was looking for the same, and was not able to find something suitable.
ATM u can use an input_number. But thats not realy intuitive for selectig a color.
Usecase for is to select a certain number of colors for a light effect.
Yeah, that card is great… I use it for my lights already.
Basically, I’m thinking we need an entity type (I propose input_color) that can hold color attributes (bonus points for different color modes besides rgb_color, like hs_color or color temperature ), but isn’t dependent on any particular device state.
EDIT: This would probably need a custom card for manipulation in Lovelace, but obviously it would be desirable to be able to edit it directly in the entity dialog, similarly to the way colors (for lights) work now.
I’m just trying to think of ideas here… How about creating a template_light so you have the colour wheel as your picker, then somehow code to link that to whatever light entity you want to control, dynamically through Lovelace. I’m not entirely sure how to do it, but thought that it could maybe be possible.
Thinking about it some more, given that any colour attributes you select for a ‘dummy’ light would be saved, you could surely use those in a script/automation to be given to any other light you want. Fairly certain that would be pretty straight forward.
So that doesn’t exactly work for my specific use case… I can’t set the color_template of my template light, because the color state reported by WLED isn’t in HS color.
Now that Helpers have been better integrated into the UI… I think this feature request needs to be revisited. Right now I set an input_text to the RGB value I want by typing it in, but would like to just choose from a color picker.
I am also looking for a color picker helper. I want to avoid hard coding colors in my automations (in Node Red) and would like to use a color picker for this purpose, which I would use on an admin panel.
Bonus points if the helper class could also include built in methods / helpers to interconnect between different color modes (8 bit RGB, 24 bit RGB, HSV, etc)
I think this could also simplify coordinating lights without integrating them into a light groups, and for rapidly re-coloring UI components.
For instance, you could have automations that set colors to day mode and night mode in the UI.
Maybe this is a niche use case? But I think it would be useful.
My use case is a simple Display with RGB-LEDs.
I want to have one place to set the color for all LEDs of the Display at once. And reference in the automation to this stored value. So the user has the choice which color the user like, and don’t have to change the automation.
I also want to set the brightness.
