Color scenes
I need some help.
I have 4 lifx lamps and I want to make some scenes to change the colors. The problem is that I must set on state to all lifx lamps in order to set the colors. Is there any way to change the colors between scenes only in turned on lamps?
The ideal is also set colors to turned off lamps to be the same when I decide to turn on individually a lamp.
Thank you
