Hello all! Trying to figure out how to control cwww leds color temperature with rotary encoder. Can’t find anything in the esphome documentation or google.
Here is my code. Need to paste something instaead of “???”
esphome:
platform: ESP32
board: lolin32
wifi:
ssid: !secret wifi1_ssid
password: !secret wifi_pass
fast_connect: on
manual_ip:
static_ip: 192.168.1.56
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Mirror Fallback Hotspot"
password: !secret esphome_ap_pass
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret esphome_pass
ota:
- platform: rotary_encoder
pin_a: GPIO19
pin_b: GPIO23
resolution: 1
internal: true
on_clockwise:
if:
condition:
binary_sensor.is_off: encoder_button
then:
- light.dim_relative:
relative_brightness: 5%
else:
on_anticlockwise:
if:
condition:
then:
relative_brightness: -5%
else:
binary_sensor:
- platform: gpio
pin:
number: GPIO18
mode: INPUT_PULLUP
inverted: True
internal: true
on_click:
min_length: 50ms
max_length: 350ms
then:
- light.toggle:
transition_length: 0.1s
on_double_click:
min_length: 50ms
max_length: 350ms
then:
- light.turn_on:
color_temperature: 4500 K
transition_length: 0.5s
- platform: status
output:
- platform: ledc
pin: GPIO1
frequency: 156250
- platform: ledc
pin: GPIO3
frequency: 156250
light:
- platform: cwww
warm_white: pwm_ww
cold_white: pwm_cw
warm_white_color_temperature: 2700 K
cold_white_color_temperature: 5500 K
constant_brightness: false
switch:
- platform: restart
I will be glad for any help!
