Colored Air quality sensor in Lovelace
Hi all,
I live in a city with high levels of pollution so I want to monitor air quality and change my behavior accordingly.
I created a aiqn sensor (that uses data from Italian environment agency) and a template sensor to translate numbers in words (from 50 to healthy and so on).
My next goal is to create a new sensor to use it in my Lovelace home page:
There’s a way to create a square box that changes colors based on values?
Something similar to the gauge sensor but without the gauge…
Thank you in advance
You could use the image card and create the images for each condition and set that in your card
- type: image
  entity: sensor.air_quality
  title: Air Quality
  image: /local/lovelace/normal.png
  state_image:
    "High": /local/lovelace/high.png
    "Medium": /local/lovelace/medium.png
    "Low": /local/lovelace/low.png
  style:
    left: 12%
    top: 1%
    transform: none
    width: 24px
    height: 24px
The above is obviously part of a picture elements card in Lovelace. Here is mine I don’t use state conditions as it never goes out of green but could be easily implemented.
It seems easy and clear. I will try and post results. Thank you!
Works like a charm!
Thank you!
