I’ve had success migrating over some bulbs from Tasmata, I’m left with some that I’m stuck on.
These bulbs use PWM1 for brightness and PWM2 for color temperature (instead of PWM1 for Cold White and PWM2 for Warm White).
In Tasmota they work using Module 48, does anyone know if there is anything I can use in ESPHome to make these work?
Thanks!
Edit: found the answer: https://github.com/ozeraser/ESPHome
This is for some of the kogan white warm bulbs - most I’ve received used 2 channels in standard format but recent batch had this buggering about built in.
