Column Calendar View - Family Calendar
I try to find a calendar view similar to “Family Calendar” but none of my searches where pointing somewhere. Neither HACS nor somewhere else.
Each Calendar gets a own column in x axis. Time in y axis.
Calender
				Cal 1|	Cal 2  | ....
Date	time
1.1.24	..
		11		event	event
		23			    event
2.1.24	..
		10		event
		23		event   event
Feature Request’s work best if you pick an integration or core function, state why is not to your liking, then what you think it should do.
If you have a specific idea how to fix it, that would be there last.
This appears to be missing a few of those components. We won’t be able to tell what you think needs fixing on what, and what you think it should look like.
Should look like this:
This is, for me, the best view on a wall mouted tab for larger families. The days should also be expandable to any scale (hour, half hour etc.)
And now I hope I placed that post in the right possition.
I have the same need. My actual solution is to place the calandards on the dashboard side by side, but that leads to the effect, that the times are not synchronized. I used the atomic calendar revive card: totaldebug/atomic-calendar-revive: An advanced calendar card for Home Assistant Lovelace. (github.com)
Is there a better way to solve this? Does anybody know about a card which helps out?
I know this thread is over a year and a half old - but does anybody knows of any calendar card that does this feature?
A calendar card that is able to show a various number of calendar entities side by side with kind of sychronized scrolling. Exactly wht the thread creator was looking for…
