Comatibility of Moes (TuYa) wall switches with Zigbee2Mqtt
I use Zigbee2Mqtt with Conbee II stick. I tried to find out the compatibility of some wall switches but it looks like the model numbers don’t match with zigbee2mqtt device repository. I also tried to search history in other places but either links to moes website expired or manufacturer changed model naming.
I hope someone could confirm that my assumptions are correct and these devices are indeed supported by zigbee2mqtt:
ZS-DL-EU3-L-WH-MS
On search results the picture is different the on the device page:
https://www.zigbee2mqtt.io/devices/TS0601_switch.html
ZS-EU3-WH-MS
https://www.zigbee2mqtt.io/devices/ZTS-EU_3gang.html
ZS-EUD3-WH-MS
I found only 2 gang switch:
https://www.zigbee2mqtt.io/devices/ZS-EUD.html
ZS-B-EU3-WH-MS
I didn’t find equivalent for this on zigbee2mqtt.io
I have rarely seen tuya devices which is difficult to integrate into ZigBee2mqtt. Thanks to its guides on integration new devices (specifically for tuya), it can be straightforward even if it not supported out of the box. Interested to hear if there are negative experiences too
Thank you for your responses. @aceindy, did you use zigbee2mqtt or deconz? It’s not clear from your post.
Zigbee2mqtt…
But now that i think of it… the motion sensor is RF… I have to re-check if it supports zigbee at all :thinking:
