So I am expecting my heating system to be upgraded from 1970s oil fired to modern a gas combi boiler next month and it presents some automation questions.
Currently I put a SOnOff basic on the thermostat lines of the existing day timer in the kitchen cupboard. The only control I have over the heating is “ON/OFF”.
The new boiler (Worcester Bosch Energystar 30i) has got Live neutral and earth for accessories and controls and live return wires for heating and hot water ON/OFF.
So for step one, I can remove the link wire and put my SOnOff in their and have basic ON/OFF control for heating, leaving the hot water link in place to leave it always available, true to combi style.
However, the boiler has an external control port for manufacturer or third party integration via the EMS protocol and I can either make or buy a converter to get OpenTherm support for the boiler. This will give me access to things like the loop temp or even to inject temperature and let the boiler manage set-points. (Need much more research here).
My first questions are more around the best way to manage the boiler rather than how to automate it.
As it’s condensing it’s important that the loop return temp is kept below 54C or it will stop condensing and lose efficiency. So for “stage one” I can just set the loop temp manually to something that will make that always the case… like 55C and assuming the install engineers make any attempt at all to balance the system it should return cooler.
However for step two, if/when I gain automated control of the heat loop I want to move to a more constantly on (when I’m in the house) model by varying the loop temp based on the largest differential between a temperature and it’s target temperature. ie. backing the boiler off as it approaches set-point so that the boiler more or less stays running at a lower temp, rather than cycling and chasing with a simple ON/OFF.
I don’t intend to run the boiler 24/7 at a low temp as research suggests this would not be the most efficient use in my case due to living in an older house with higher heat loss it will be more efficient to let the house cool when I’m out or in bed.
I don’t want to go to EvoHome or similar at this stage, but instead implement my own logic to do similar. A large part of the reason is that I feel capable of creating a custom solution that may be better for my individual circumstances and a second part is that EvoHome is extremely expensive and badly priced.
So I would like to hear your thoughts, advice, ideas, concerns.
