Combine 3 sensors to one (ESPHOME)
I want be able to monitor my Windows in my home. I have 11 windows and the status of the windows can be:
  • Closed
  • Open
  • Tilted
I am now making a PCB with 3 reed sensors, ill print a mount with a magnet so when the handle is turned between the 3 options the reed switch will trigger a esp32.
At this point my setup works, but i have 3 sensors for 1 window.
In the end i would like to have one Sensor (published) like:
Kitchen Window: Open/Closed/Tilted.
The code i have been using so far:
binary_sensor:
  - platform: status
  - platform: gpio
    pin: 4
    device_class: window
  - platform: gpio
    pin: 2
  - platform: gpio
    pin: 35
  - platform: adc
    pin: 32
    update_interval: 60s
    attenuation: auto
deep_sleep:
  run_duration: 10s
  sleep_duration: 10min
  esp32_ext1_wakeup:
    pins:
    - 4
    - 2
    - 35
    mode: ALL_LOW
I hope anyone here has some good information :), i cant find it so far!
Template sensor
Template Sensor — ESPHome
binary_sensor:
  - platform: status
  - platform: gpio
    pin: 4
  - platform: gpio
    pin: 2
  - platform: gpio
    pin: 35
  - platform: adc
    pin: 32
    attenuation: auto
    lambda: |-
      if (id(open).state) {
        return "Open";
      } elseif (id(closed).state) {
        return "Closed";
      } elseif (id(tilt).state) {
        return "Tilted";
      } else {
        return "Unknown";
    update_interval: 5s
deep_sleep:
  run_duration: 10s
  esp32_ext1_wakeup:
    pins:
    - 4
    - 2
    - 35
    mode: ALL_LOW
Maybe what you want can be achieve with a template text sensor
Something more or less like this might work? The Mijn Raam sensor should expose the three string values depending on the magnets that get triggered. (You might need to debounce the signal if you use reed contacts, maybe not)
text_sensor:
- platform: gpio
    pin: 4
    internal: true
    on_press:
       then:
        - text_sensor.template.publish:
               state: "Closed"
  - platform: gpio
    pin: 2
    internal: true
    on_press:
       then:
               state: "Tilt"
  - platform: gpio
    pin: 35
    internal: true
    on_press:
       then:
               state: "Open"
Thanks! That did the trick!
text_sensor:
binary_sensor:
  - platform: status
  - platform: gpio
    pin: 4
    on_press:
       then:
               state: "Dicht"
  - platform: gpio
    pin: 2
    on_press:
       then:
               state: "Tilt"
  - platform: gpio
    pin: 35
    on_press:
       then:
               state: "Open"
  - platform: adc
    pin: 32
    attenuation: auto
deep_sleep:
  run_duration: 10s
  esp32_ext1_wakeup:
    pins:
    - 4
    - 2
    - 35
    mode: ALL_LOW
if you can use an input select (helper) with “raam x status” --.> dicht, gekanteld or open (english closed,tilted or open) and have an automation change the state of the helper reflecting the setting.
if this works you can list only 11 (1 per window)
