Hello!
My weather integration (KNMI) has multiple states e.g. rain, cloudy, lightning etc. Is it possible to combine these into one state (e.g. bad weather) that can be used as a condition in automations?
Thanks for any input!
Hello!
Yes, with a template sensor. You’d build the if-then logic to determine if the weather is good or bad.
Thanks!
To follow up on that, I have little knowledge on yaml and how to do the above correctly. I started with the following but since I don’t really know what I’m doing, I’ll have to ask again. Also I guess there must be an easier way to do this, perhaps use if not
for the states of the entity that don’t represent bad weather.
template:
- sensor:
- name: "Slecht weer"
state: >
{% if is_state('weather.knmi.thuis', 'Gedeeltelijk bewolkt') %}
slecht weer
{% elif is_state('weather.knmi.thuis', 'Bewolkt') %}
slecht weer
{% elif is_state('weather.knmi.thuis', 'Rainy') %}
slecht weer
{% else %}
goed weer
{% endif %}
