I have a treatlife combo light and fan switch that I’ve flashed ESPHome onto. It has a switch that controls the light, and a number value that controls the brightness setting.
How can I combine these two separate items into a single light object so I can use the standard light card to control both the light being on/off along with its brightness setting?
I think I’m missing something here, it looks like the monochromatic light is always on but varies the brightness so 0 has the light “off” by being to dim to see and it becomes brighter the larger the number.
I still need to use switch to turn it on/off and then a separate brightness value. For some reason I hadn’t thought about looking at the ESPhome side of things, I’ll read more on that side to see what obvious thing I’m missing, lol.
I found it, thanks. I don’t know why I had a complete and utter brain fart there
This is for the treatlife DS03 for those interested. I’ve seen some existing config files for the DS03 and ESPhome, but for whatever reason I noticed that my pinout information is different. It could be things changed, I’m not 100% sure, but here’s my relevant ESPhome section for the light and the fan.
