"Combine the state of several sensors" - how to edit existing definitions
Having created various “Combine the state of several sensors” helpers via the UI, I now find that I need to edit some of them to add or replace sensors used in them. The UI doesn’t seem to allow me to do this, so I guess I need to edit the definitions in the config files somewhere. Can anybody tell me where to find the definitions please, or how to get the UI to let me edit an existing helper? Many thanks
It can be easy to miss, but you can edit the helper. Open the sensor dialog box (such as by clicking on it on the helpers tab) and click the gear icon to go into settings. About half way down the dialog, just after the “label” field will be a choice to go to the helper’s specific settings. For the “combine” helper, this is called “Combine the state of several sensor options”.
