Combine time input sliders with time trigger
According to the templating page, the time trigger automation syntax is as follows:
automation:
    platform: time
    # When 'at' is used, you cannot also match on hour, minute, seconds.
    # Military time format.
    at: '15:32:00'
Rather than 15:32:00, I need to use a time specified from the frontend. I’m using the following sensor for time:
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'time_date'
      - 'time_utc'
      - 'beat'
And the specified time is set with this:
input_number:
  wakeup_hour:
    icon: mdi:clock-in
    initial: 6
    min: 0
    max: 23
    step: 1
  wakeup_minutes:
    icon: mdi:clock-in
    initial: 30
    min: 0
    max: 59
    step: 1
  wakeup_duration:
    name: Light Fade-In Duration
    icon: mdi:clock-in
    initial: 10
    min: 5
    max: 60
    step: 5
input_boolean:
  wakeup:
    name: 'Enable Wake Up Light'
    icon: mdi:power
    initial: off
Reformatted like this:
    sensors:
      wakeup_time:
        friendly_name: 'Alarm Time'
        value_template: '{{ "%0.02d:%0.02d" | format(states("input_number.wakeup_hour") | int, states("input_number.wakeup_minutes") | int) }}'
How do I modify the trigger at the beginning of the post to trigger at the wakeup_time?
