Stavros
(Stavros McGillicuddy)
1
Can I consolidate these two automatons into one?
alias: HVAC Cool
description: Over 70
- platform: numeric_state
entity_id: weather.home
attribute: temperature
above: 70
condition: []
- service: climate.set_hvac_mode
hvac_mode: cool
entity_id: climate.living_room
mode: single
alias: HVAC Heat
description: Under 55
below: 55
condition: []
hvac_mode: heat
mode: single
tom_l
2
Sure. Give your triggers each an id and use a choose action based on a trigger condition.
123
(Taras)
3
You can employ trigger.id
directly in hvac_mode
alias: HVAC Cool
- id: 'cool'
above: 70
- id: 'heat'
below: 55
condition: []
hvac_mode: '{{ trigger.id }}'
mode: single
Stavros
4
Very elegant… Thanks!!
So, the trigger id value becomes the mode value that is passed in hvac_mode… Have I got that right?
123
(Taras)
5
Yes, that’s correct.
If you needed to pass more than one value, you can use trigger variables instead of id
