Hi. I am very new to Lovelace and custom cards, so if I can’t get a full solution could someone please help by pointing me to any existing docs on how to achieve below.
I basically want to have a single row entity that has a sensor on the left as the image and the switch to another entity on the right. They don’t need to interact with each other - this is just a graphical/layout issue.
In my pic below is my garage door sensor is the top row. That image changes to an open door when the sensor is activated. The next row is my switch. btw. I won’t need the sensor state text.
Hi. How do you mean? Like I said I am a mega-newb. I haven’t got a clue how to combine elements. But know it must be possible… I’m not trying to be lazy by asking for advice. Just a poke in the right direction would be good.
I believe you want to create a cover entity out of several different entities. It is possible by using the template cover component. Check out the docs.
Thank you. I couldn’t work out how to implement a Template Cover to create what I want, so I am now slowly trying to design a custom card. Very slowly.
Am I right in assuming that you can’t reference an existing entity in it’s entirety in my design? ie. For example, as for my existing sensor - I can’t just reference it and the whole design drops into my new card?
Everything you see on a custom card needs to be very individually coded?
Ok. The Template covor will give you one row where you can display the icon based on a sensor state. So the garage could be open based on your sensor and vice versa. It will also give you the up, down and stop button to the right.
If you dont want the arrows and just the switch like in your above example then use the template switch component.
Thanks so much for persisting with me!
As background, I am using a Belkin Wemo Maker to control the garage door. It works as a momentary switch and also has a built-in sensor component that can be read as an attribute of the switch.
This is what I came up with - does it look OK to you?
(NB. taken from my switches.yaml file, so fix your mapping if you are adding this to configuration.yaml)
