Combine two switch into one binary sensor
I’m begining into home assistant and I have a problem with my door sensor.
my door sensors are 433Mhz sensors witch communicate with home assistant with a rflink device throw MQTT.
the output is as below :slight_smile:Client mosq/c8eNogbzLH6rmCGGI1 received PUBLISH (d0, q0, r0, m0, ‘rflink/EV1527/00235d/R/09/message’, … (13 bytes))
{“CMD”: “ON”}
Client mosq/c8eNogbzLH6rmCGGI1 received PUBLISH (d0, q0, r0, m0, ‘rflink/EV1527/00235d/R/03/message’, … (13 bytes))
{“CMD”: “ON”}
if fact the switch 9 is sended when the door is open and the switch 3 when the door is closed.
how can i combine this two switch into one binary sensor.
thanks by advance for your help.
regards,
