mclever
(mclever)
November 20, 2024, 12:38am
1
I have two switches that control a fan and its speed, one for on/off and the other for high/low. How can I combine these two switches so they will show up on a dashboard with options high/low/off instead of two separate switches?
Using fan-percent-button-row for my other fans and they look like this
This is how I currently have the two switches on the dashboard, with the speed on=high and off=low
Looks like I can use isTwoSpeedFan to remove the MED option on dashboard.
armedad
November 20, 2024, 1:23am
2
you can use a template fan. something like this:
fan:
fans:
combined_fan:
preset_modes:
- "Off"
- "Low"
- "High"
preset_mode_template: >
{% if is_state('switch.fan_power', 'off') %}
Off
{% elif is_state('switch.fan_speed', 'on') %}
High
{% else %}
Low
{% endif %}
set_preset_mode:
- choose:
- conditions:
- condition: template
value_template: "{{ preset_mode == 'Off' }}"
sequence:
- service: switch.turn_off
entity_id:
- switch.fan_power
- switch.fan_speed
- conditions:
value_template: "{{ preset_mode == 'Low' }}"
sequence:
- service: switch.turn_on
entity_id: switch.fan_power
entity_id: switch.fan_speed
- conditions:
value_template: "{{ preset_mode == 'High' }}"
sequence:
entity_id:
- switch.fan_power
- switch.fan_speed
goes in configuration.yaml
mclever
(mclever)
November 20, 2024, 2:18am
3
Looks like they changed the config options in the version of HA that I’m on
Invalid config for ‘template’ at configuration.yaml, line 429: ‘fan’ is an invalid option for ‘template’, check: fan
Template fan - Home Assistant doesn’t look to support all the same things either
mclever
(mclever)
November 20, 2024, 3:19am
4
Thanks for pointing me in the right direction @armedad . The below config works correctly when using the preset modes of the template fan, but not with the custom:fan-percent-button-row entity type. I think it’s because that tries to set the fan speeds, instead of using the preset modes and the speed switch doesn’t get updated. To be continued later…
fan:
fans:
whole_house_fan_template:
friendly_name: "Whole House Fan Template"
turn_on:
entity_id: switch.whole_house_fan
turn_off:
entity_id:
- switch.whole_house_fan
preset_modes:
- "Off"
- "Low"
- "High"
{% if is_state('switch.whole_house_fan', 'on') and is_state('switch.whole_house_fan_speed', 'on') %}
High
{% elif is_state('switch.whole_house_fan', 'on') and is_state('switch.whole_house_fan_speed', 'off') %}
Low
{% else %}
Off
{% endif %}
set_preset_mode:
- choose:
- conditions:
sequence:
entity_id:
- conditions:
sequence:
entity_id: switch.whole_house_fan_speed
- conditions:
sequence:
entity_id:
- switch.whole_house_fan_speed
mclever
(mclever)
November 20, 2024, 3:27am
5
Tried one last thing for the night. Created a new card like this and got a dropdown with presets that works correctly
features:
- style: dropdown
type: fan-preset-modes
type: tile
entity: fan.whole_house_fan_template
tap_action:
action: none
icon_tap_action:
action: none
show_entity_picture: false
vertical: false
hide_state: true
mclever
(mclever)
November 20, 2024, 4:06pm
6
Figured it out. Had to use a different card type, fan-mode-button-row, for that fan to make it work as I wanted.
- entity: fan.whole_house_fan_template
type: **custom:fan-mode-button-row**
twoModeFan: true
name: Whole House Fan
