Combine Two Switches Into One
I have four SwitchBot switches attached to my pool remote. The remote has on/off buttons for the lights and separate on/off buttons for the spa heater.
Currently, I have four instances in HA for the switches (Pool Lights On, Pool Lights Off, Spa Heater On, and Spa Heater Off). On/Off for each instance does the same thing, triggers the switch.
I’d light to just have a rocker On/Off so “On” triggers the SwitchBot attached to “Pool Lights On” and “Off” triggers the SwitchBot attached to “Pool Lights Off.” Same for the Spa Heater.
I’ve tried coding a “template switch” and an automation to no avail.
Any ideas?
Thank you!
Do you have feedback to Home Assistant that tells you the state of the lights and heater?
I’d start with a helper for pool lights and spa heater.
  1. Go to Configuration | Helpers
  2. Tap the ( + ADD HELPER ) button on the bottom right
  3. Select a Toggle
  4. Name it “Pool Lights”
  5. Do the same for “Spa Heater”
    Now you’ve got your toggles, but they don’t do anything. You need some automations as follows:
# When Pool Lights turns on, push the Switchbot for Pool Lights On
- alias: 'pool lights on'
    platform: state
    entity_id: input_boolean.pool_lights
    to: 'on'
    service: homeassistant.turn_on
    entity_id: switch.switchbot_pool_lights_on
(I’m not sure how you activate a switchbot, so you might have to change those last two lines.)
Do the same thing for pool lights off, spa heater on, and spa heater off using the corresponding helpers (input_booleans) and switchbot commands.
Thank you! The Pool Lights work intermittently but I can only get the Spa Heater to turn on, but not off. Here is what I have:
#When Pool Lights turns on, push the Switchbot for Pool Lights On
  • alias: ‘pool lights on’
    platform: state
    to: ‘on’
    entity_id: switch.pool_lights_on
#When Pool Lights turns off, push the Switchbot for Pool Lights Off
  • alias: ‘pool lights off’
    platform: state
    to: ‘off’
    entity_id: switch.pool_lights_off
#When Spa Heater turns on, push the Switchbot for Spa Heater On
  • alias: ‘spa heater on’
    platform: state
    entity_id: input_boolean.spa_heater
    to: ‘on’
    entity_id: switch.spa_heater_on
#When Spa Heater turns off, push the Switchbot for Spa Heater Off
  • alias: ‘spa heater off’
    platform: state
    to: ‘off’
    entity_id: switch.spa_heater_off
It looks like it should work as you have it. Check the indentations. (I can’t see that from your copies.) Hint: if you use three tildes (```) before and after your copied automations, it shows exact indentation and highlights parts of text like this:
- alias: ‘spa heater off’
    platform: state
    to: ‘off’
Thanks again! You’re awesome.
It appears I had the incorrect MAC address in the Config file for Spa Heater Off. Human Error!
Here is my code with the correct indentations (thanks for the tip!):
     platform: state
     to: 'on'
# When Pool Lights turns off, push the Switchbot for Pool Lights Off
 - alias: 'pool lights off'
     platform: state
     to: 'off'
# When Spa Heater turns on, push the Switchbot for Spa Heater On
 - alias: 'spa heater on'
     platform: state
     to: 'on'
# When Spa Heater turns off, push the Switchbot for Spa Heater Off
 - alias: 'spa heater off'
     platform: state
     to: 'on'
