I have two temperature sensors.
I want to create a new sensor that records the value of sensor 1, except in the hours between 07:00 and 12:00. At that interval record sensor 2 instead.
How to achieve that?
Use two template sensors triggered at the times you want.
Template sensor set up in the UI under Helpers with a state template of:
{{ states('sensor.temp2') if 7 <= now().hour < 12
else states('sensor.temp1') }}
If this is an outside temperature sensor compensating for sun load, can you just take the smaller value? I have an east- and a west-facing sensor, and taking the smaller value works well.
personally, i would do it via the ui.
go here:
choose template
then choose template sensor (not binary sensor)
name it something and for the state template put this:
{{ states('sensor.your_sensor_1') if today_at('07:00') < now() < today_at('12:00') else states('sensor.your_sensor_2') }}
