Combining a binary sensor and device tracker for presence tracking
Hi, I’m new to home assistant I’m loving the possibilities here!
Since I don’t feel comfortable with tracking my wife’s location all the time (using owntracks or any other method) I had to come up with another method for tracking her presence.
I want to use bluetooth and my fingbox. There are however some limitations here:
Fingbox sends an email when someone is on the network and that email triggers ifttt to set a binary_sensor in Home Assistant. There is a one minute delay in this setup.
Bluethooth detects and changes the presence faster. But the range is smaller then my wifi range and sometimes it doesn’ see a person when the person is in fact ot home.
So I was thinking of combining these two but I can’t figure out how. I need something like this:
device_tracker_person = home if device_tracker_person_bt = home or binary_sensor_personhome = 1
How would I do this?
Thanks!
Instead of tracking your wife all the time you might consider detecting her device on your local network. She probably won’t object to that. You should have a look at the nmap device tracker or one specific for your router. I use asuswrt with great success.
I considered Nmap but since I already have a fingbox for network detection I want to keep using that method.
The router I am currently using is not supported for presence detection.
You could try to have hour fingbox set a (dummy) device tracker entity with a value home or not_home instead of a binary sensor (or create one with a template sensor). Then you can simply create a group with both device trackers, that will show home if one of both is home.
Thanks! It worked with the solution you suggested.
To improve my karma, you could like and mark my solution :slight_smile:
