Combining automatisations
I’m a newbie on Home Assistant and I could/would like some help with my automations.
I have a minibieb (Little free libary) that is equiped with a open/close sensor (433 mhz, recieved by a Sonoff RF-bridge running Tasmota). Currently I’ve got two automations, one for when it’s opened and one for when it’s closed.
alias: Melding - Mini bieb (openen)
description: ''
  - platform: state
    entity_id: binary_sensor.mini_bieb
    to: 'on'
condition: []
  - service: notify.telegram
      message: Test
        photo:
          - url: 'http://10.25.10.90/Streaming/channels/1/picture'
            authentication: digest
            username:
            password:
            caption: De mini bieb wordt geopend
mode: single
This automation sends a picture through Telegram informing us the libary is being opened.
My second automation is:
alias: Melding - Mini bieb (sluiten)
description: ''
  - platform: state
    to: 'off'
condition: []
      message: De mini bieb wordt gesloten
mode: single
This is informing us that the libary is being closed.
Instead of two automations I would like to have one automation, accomplishing the same.
Zoiets als dit?
- alias: Melding - Mini bieb (openen/sluiten)
  mode: single
    - platform: state
        message: Test
          photo:
              username:
              password:
              caption: >-
                {% if trigger.to_state.state == 'on' %}
                {% else %}
                {% endif %}
Via de UI was ik op dit gekomen en dat werkt ook, die van jou is wel wat compacter./
Through the UI I created this and it seems to work, yours is a bit more compact.
alias: Melding - Minibieb
description: ''
  - platform: state
condition: []
  - choose:
      - conditions:
          - condition: state
            state: 'on'
        sequence:
              message: Test
                photo:
                    username:
                    password:
      - conditions:
          - condition: state
            state: 'off'
        sequence:
    default: []
mode: single
Ik heb jouw code geprobeerd maar krijg een melding:/
I’ve tried your code but got an error:
Message malformed: expected dictionary
Wel jammer dat je vrij weinig gegevens krijgt omtrent waar het fout gaat./
It’s kind of sad that you don’t get that much info about where the error fails.
Guys, please keep it in English.
The automation from @poudenes is not going to do what you want as it will send a picture no matter if it is open or closed and as I understand you only want a picture when it gets opened.
The automation you posted can be made a little more compact by using shorthand conditions and removing the empty condition and default action, otherwise you can’t make it more compact.
description: ''
  - platform: state
  - choose:
      - conditions: "{{ states('binary_sensor.mini_bieb') == 'on' }}"
        sequence:
              message: Test
                photo:
                    username:
                    password:
      - conditions: "{{ states('binary_sensor.mini_bieb') == 'off' }}"
        sequence:
mode: single
nice to see other way of automation. Didn’t know you can do 2 conditions in a choose without a default
