Combining components of like type?
In trying to understand Home Assistant and Hass.io and the configuration.yaml file, I noticed that the yr sensor was installed by default and was listed in the config file as:
  - platform: yr
Later I added the Weather Underground component to the config file as required.
  - platform: wunderground
    api_key: your_api_key
    monitored_conditions:
      - alerts
Then I thought, they both have “sensor:” in them, why not combine them? So I did this:
  - platform: yr
      - alerts
But that would not pass config check. The question is why not? Is this by design, or do I have bad format in the config file?
Thank you in advance.
You have a bad format.
Try adding at least one option to the YR sensor, like for example name or monitored conditions
Thank you treno. That worked.
