Combining different binary sensors
I cannot combine binary TOD sensors and other binary sensors in one packade . Generates an error . If I move binary TOD sensors to another package, everything works . How to connect in one package different binary sensors ?
grid_city:
  template:
    - binary_sensor:
        - name: spm90_voltages
          unique_id: spm90_voltages
          delay_off:
            minutes: 3
          state: >
            {{ states('sensor.spm90_voltage')|float(default=0) < 380 }}
        - name: grid_city_on
          unique_id: grid_city_on
          state: >
            {% set voltage = is_state('binary_sensor.spm90_voltages', 'on') %}
            {% set high_tariff = is_state('binary_sensor.high_tariff_morning', 'on') or
            is_state('binary_sensor.high_tariff_evening', 'on') %}
            {{ voltage and high_tariff }}
      # Π”Π΅ΡˆΠ΅Π²ΠΈΠΉ Ρ‚Π°Ρ€Ρ–Ρ„ Ρ€Π°Π½ΠΎΠΊ
        - platform: tod
          unique_id: high_tariff_morning
          after: "08:00"
          before: "11:00"
        # Π”Π΅ΡˆΠ΅Π²ΠΈΠΉ Ρ‚Π°Ρ€Ρ–Ρ„ Π²Π΅Ρ‡Ρ–Ρ€
        - platform: tod
          unique_id: high_tariff_evening
          after: "20:00"
          before: "22:00"
  automation:
    - id: auto_turn_grid_low_battery
      alias: auto_turn_grid_low_battery
      initial_state: true
      - platform: state
        entity_id: binary_sensor.grid_city_on
        to: 'on'
      - platform: state
        to: 'off'
        - choose:
          - conditions:
            - condition: state
              state: 'on'
            sequence:
            - service: switch.turn_on
                entity_id: switch.0xa4c1386199f45931
          - conditions:
            - condition: state
              state: 'off'
            sequence:
            - service: switch.turn_off
Please don’t post screenshots but actual yaml, properly formatted. This way we cannot copy/paste etc.
You are mixing two binary sensor types. This binary sensor is under template, so it is a template binary sensor, not a tod binary sensor.
The tod sensor needs to by inder binary sensor at top level.
I raised the TOD sensors to the upper level. The error did not go away
Help please
grid_city:
    template:
      binary_sensor:
        - platform: tod
          after: "08:00"
          before: "11:00"
        - platform: tod
          after: "20:00"
          before: "22:00"
          delay_off:
            minutes: 3
          state: >
          state: >
    automation:
            initial_state: true
            - platform: state
              to: 'on'
            - platform: state
              to: 'off'
              - choose:
                - conditions:
                  - condition: state
                    state: 'on'
                  sequence:
                - conditions:
                  - condition: state
                    state: 'off'
                  sequence:
No, you did not, there’s still template: above it, that should not be there.
Compare that with the docs:
# Example configuration.yaml entry
binary_sensor:
  - platform: tod
Everything works. Thank you for your help
