Hi! Can someone help me out with this?
Ik have this Home Connect integration and it does display every part of the Oven as a separate sensor. So like the sensor names are:
switch.oven_power (values: on or off)
switch.oven_program_preheating (on or off)
sensor.oven_program_progress (xxx%)
I wish to display the state of the oven in a picture-glance. So, I can show the state of the oven with the corresponding picture.
The problem is, there are multiple sensors. So, I canāt use state_image with:
state_image:
ā1ā: /local/ oven_off.png
ā2ā: /local/ oven_on.png
ā3ā: /local/ oven_pre.png
Etc.
Is there someone who knows a solution for this?
I was thinking of a template that can combine the sensor entityās and generate an new oven.entity with a state from 1 to 5 or something. From that state, I can use the picture glance with state_image: 1, 2, 3 etc.
Such a state could be calculated by IF switch.oven_power is on AND switch.oven_program_preheating is on AND sensor.oven_program_progress is < 1% THEN state must be 3. For example.
I canāt get my head around this how I should program such a template. Is there someone that understands the templating deeply enough to get me underway? Iāve been breaking my head on this all day.
I wish to use the standard out of the box home assistant tools, no custom components.
Iām trying a simpler template below (skipping the preheating part). But I get an template running error in the /developer-tools/template/ Itās not telling why. Not getting it fixed today. Iāts late, need to continue another day. Maybe it has something to do with is_state
Yeah! Itās working. This example can be used to drive state-image in a picture glance the lovelace frontend. Iāve been adding other sensors then I mentioned before in my request.
Maybe itās nice to add it to the documentation for other users at. https://www.home-assistant.io/integrations/home_connect/
Aldough I understand there are mabye other ways to archive the goal if youār really good at templating. Iām continuing to finetune it now.
sensors:
oven:
friendly_name: "Oven"
value_template: >-
{% if is_state('switch.oven_power','off') %}
Standby
{% elif is_state('switch.oven_power','on') and is_state('switch.oven_program_600watt','off') and is_state('switch.oven_program_hotair','off') and is_state('switch.oven_program_pizzasetting','off') and is_state('switch.oven_program_preheating','off') and is_state('switch.oven_program_topbottomheating','off') %}
Power-on
{% elif is_state('switch.oven_power','on') and is_state('switch.oven_program_600watt','off') and is_state('switch.oven_program_hotair','off') and is_state('switch.oven_program_pizzasetting','off') and is_state('switch.oven_program_preheating','on') and is_state('switch.oven_program_topbottomheating','off') %}
Preheat
{% elif is_state('switch.oven_power','on') and is_state('switch.oven_program_600watt','on') %}
Microwave
{% elif is_state('switch.oven_power','on') and is_state('switch.oven_program_hotair','on') %}
4Dhotair
{% elif is_state('switch.oven_power','on') and is_state('switch.oven_program_pizzasetting','on') %}
Pizza
{% elif is_state('switch.oven_power','on') and is_state('switch.oven_program_topbottomheating','on') %}
Toptobottom
{% else %}
Finished
{% endif %}
And the corresponding picture-glance could look like this:
Because some sensors didnāt work at all, they donāt get a value from Siemens.
Other sensors look great on first sight, but complicated the formula then using. For example the duration behaviour is not always useable or the same on every machine.
If you have a different machine, you can also have different sensors then in the example.
Probably also works on Bosch Home Connect.
You can modify the code for other Home Connect appliances. Other sensors mean other possabilities!
Make your own graphics (I canāt supply them, but you could screen copy them form the official siemens app for exampleā¦) Aldough the naming suggest lots of images, I actually recylce 1 PNG picture for all programs, I donāt have photoās of them all
hi there, do you have templates for other devices such as oven, cooker & glassdraft/downdraft? Also it would be nice if you share a example picture as i am fairly new to HA i am not sure if i should start reading into it or if i queue this for later
Iām having issues with my Siemens dryer progress sensor here, which never exceeds ā0ā %.
The end time, is updated accordingly. I really have no clue hoot fix this.
I think the only progress sensor which truly works as intended is the one for my Siemens dishwasher.
Someone has the same problems using HA 2025.8 and the home connect integration?
(It was a problem before)?
